Couple questions about my 88 T4R
Old Jun 2, 2018 | 11:51 AM
881stgen's Avatar
Noticed some liquid dripping from under the rear axle and so I took a look and saw this.... Does it look like the brake cylinder is leaking? Or is this gear oil? I have no idea. It's only on passengers side.
Also, I noticed it doesn't seem to sag in the rear and I don't know what the rear suspension is supposed to look like. I'd like.to do the zuk mod but it seems like there are little blocks under the leaf springs. Was that how PO leveled the rear?
Old Jun 2, 2018 | 12:30 PM
millball's Avatar
It is easy to smell and feel with your fingers the difference between brake fluid and gear oil.
Does your brake master cylinder reservoir show fluid loss??
The leak at the diff center is most likely gear oil, unless a brake line is holed.
Old Jun 2, 2018 | 03:14 PM
wyoming9's Avatar
Red face
I vote for gear oil leaking wheel cylinder would have caused one of those Brake pedal to the floor adventures
At least enough of loss brake pedal to catch your attention
Plugged breather vent Hot Gear oil !!
Old Jun 2, 2018 | 03:30 PM
RAD4Runner's Avatar
Like Wyoming says.
It is not difficult to remove the wheels and brake drum to inspect and be certain.
That block is a band-aid. If gives you better ground clearance than the saggy rear-end (common) but does not improve your ride. IF you want a smoother ride, restore ground clearance, but do NOT WANT to spend too much money, search Zuk Mod. I did mine for under $100.
Old Jun 2, 2018 | 05:47 PM
wallytoo's Avatar
if it is gear oil, you will need to replace the brake shoes, along with the bearing. heck, even if its brake fluid, those shoes need replacing, there's fluid covering the inner drum surface and components.
Old Jun 3, 2018 | 08:22 AM
881stgen's Avatar
So it's definitely gear oil. I ordered a new breather valve. I just got a stock style since I don't do any serious off reading and unless ˟˟˟˟˟ hits the fan there won't be any time a modified breather will come into play.
Part of the reason I thought it was the brakes is because I have to press pretty hard to stop, but it doesn't ever drop the pedal. It also pulls when I brake, but maybe that makes sense? If one of my brakes is essentially not working because it's covered in gear oil that could be why it pulls and also requires more force to stop?
So the other question I have is if the breather is plugged and it pushes past the seals are the seals ruined? Do I need to replace all the seals on the diff now too?
I was planning on pulling the drums apart anyway to redo them so I could service the diff as well
Old Jun 3, 2018 | 08:23 AM
881stgen's Avatar
Like Wyoming says.
Im definitely going to do the zuk mod!!
Old Jun 3, 2018 | 08:37 AM
wallytoo's Avatar
i'd replace the bearing/seal, especially if you can't confirm that the breather caused the leak in the first place. you only need to replace them on the side that failed.
your brake pull and extra effort needed are indicative of the contaminated brake shoes on that side. you should replace the shoes on both sides of the rear axle, and thoroughly clean the braking surface of the contaminated drum before reinstallation.
Old Jun 3, 2018 | 09:04 AM
RAD4Runner's Avatar
i'd replace the bearing/seal, ...
Yep. Same project I'm on. Ordered the whole rear axle bearing/seals kit from Marlin Crawler.
Parts and Alexman Videos' procedure here: https://www.yotatech.com/forums/f116.../#post52399536
Old Jun 3, 2018 | 09:45 AM
wallytoo's Avatar
Same project I'm on. Parts and Alexman Videos' procedure here: https://www.yotatech.com/forums/f116.../#post52399536
except for the shoes, right? you caught the bearing failure before it leaked?
Old Jun 3, 2018 | 01:48 PM
RAD4Runner's Avatar
Correct, Wallytoo, brakes are good. No leaks but I heard rhythmic hum on my return drive from Utah. (Our senses are the best troubleshooting tools.) No shaking, no vibration, and hum remains even after I had tires balanced and rotated. Brother-in-law who's a mech took it for a spin. He does not think it's drivetrain. I listened to tranny, transfer case, observed drive shaft, differential and hubs. Hubs sounded louder and bearings almost gritty. So I'm 99% sure it's the bearings. Odometer at 251,145 miles after Utah trip. not bad for rear wheel bearings?
Old Jun 4, 2018 | 12:03 AM
wyoming9's Avatar
Red face
As to the seals having failed you never know till it is all back together and your driving again.
Peace of Mind replace while things are apart or you might be taking it apart again.
881stgen
May 6, 2018 01:29 PM
paynemw
12
May 21, 2012 09:40 PM
topdown4runner
May 6, 2010 05:12 AM
RMRanger
Aug 29, 2008 12:24 AM
Joey Link
7
Dec 31, 2007 08:59 AM
