Torqe for bolts
Old Jun 13, 2018 | 02:24 PM
jjrbus's Avatar
Torqe for bolts
I have read the FSM 2 times and did a web search and cannot find the torque for the pulley behind the fan clutch, I have read the fan blade is 48 inch lbs 17 times! The one the power steering pump belt is on. This one pictured.
Old Jun 13, 2018 | 11:32 PM
wyoming9's Avatar
Red face
I have only ever snugged them up using a 10mm wrench
I am not sure if any torque wrench would be able to even fit in there as a 1/4" ratchet won`t
The trick is to get them even
Old Jun 14, 2018 | 02:59 AM
jjrbus's Avatar
Thanks for the response, I have given up looking for a torque value.
Not being much of a mechanic but knowing torque is important if I cannot get a torque wrench in someplace. I set a torque wrench to the setting and then practice on something else with the torque wrench and the wrench I will use to get a feel for the proper torque.
Old Jun 14, 2018 | 09:08 AM
RAD4Runner's Avatar
Originally Posted by jjrbus
.... I set a torque wrench to the setting and then practice on something else with the torque wrench and the wrench I will use to get a feel for the proper torque.
Good idea. Try doing that without grasping the wrench with your hand. Instead, just leverage with thumb at bolt end of 10-mm wrench and pinky or other finger at other end of the wrench. That should be gentle enough torque not to damage metal threads.
cartune777
Oct 30, 2012 06:59 AM
Bipper Bip Bizzip
Dec 17, 2011 10:12 AM
artemisentreri1978
Jul 25, 2008 04:35 PM
krustyroo
May 24, 2007 11:19 AM
