Can't Find 2WD Pitman Arm!
Old 05-12-2018, 12:55 AM
Toyota345's Avatar
Angry Can't Find 2WD Pitman Arm!
Hey everyone, I'm going through the steering on my '89 Pickup w/ power steering; new tie rod ends, ball joints, idler arm, etc. I cannot find a 2WD pitman arm ANYWHERE. Does anybody know where I can find one?
Old 05-12-2018, 07:14 AM
wyoming9's Avatar
Red face
Just what is wrong with yours ??
As far as I remember The 2wd and 4x4 until they changed to a steering Rack share the front steering parts
Never having seen a 2wd Toyota it is only from what I read
Old 05-12-2018, 08:29 AM
Toyota345's Avatar
I'm just replacing it because the truck has 240K miles on it and has all the original front end parts still, even TREs and ball joints, and I imagine that the joint in the pitman arm is not in the best of shape. And the pitman arm on the 2WD and 4WD trucks are not the same; the pitman arm on the 2WD trucks from what I gather are ~1" shorter, and are flatter than the 4WD arms.
Old 05-12-2018, 09:03 AM
mldave's Avatar
Did you try Rockauto.com
Old 05-12-2018, 10:49 AM
wyoming9's Avatar
Red face
Best of luck in that case !!
My Napa listing must be wrong then as it lists the same part number for both .
I should ask Power steering or Manual ??
Have you tried your Toyota dealer sometimes you get lucky with older parts??
Old 05-12-2018, 03:58 PM
SENOR NOODLES's Avatar
The pitman arm (for 2wd) does not have any wearing parts. Why would you replace? They could be had used. I have one off a 85 2wd. Should be the same.
I have found parts that have no parts to wear out, usually do not have a replacement available.
Old 05-12-2018, 09:26 PM
Toyota345's Avatar
Mine has something that resembles a ball joint in one end. Similar to the 4WD arm I believe. Am I wrong? That''s how it appears in mine.
Old 05-12-2018, 09:27 PM
Toyota345's Avatar
No dice.
Old 05-12-2018, 09:35 PM
Toyota345's Avatar
After much searching and calling around, a Toyota dealership ~40 min from me has one in the back room, just by luck. Gonna go grab it tomorrow. Thanks to all for their input.
Old 05-13-2018, 12:16 PM
Robert m's Avatar
This^^^
Either yours isn't stock and someone some how put a different pitman arm and centerlink on it or, it's not a 5 lug 2wd pickup. On the 5 lug setup, the ball joint part is on the centerlink, not the pitman arm itself.
Old 05-14-2018, 01:57 PM
Originally Posted by Robert m
This^^^
I could have sworn I seen a tie rod built into a 2wd arm once. I was wrong. I was going off what I thought I remembered, and wasted time looking for an arm online for like 20 minutes, until I walked out to the driveway and confirmed I was wrong about the arm.
I was just thinking about it....the arm I have has 475k on it. I wouldn't waste the time or money unless the arm is obviously damaged. It would be a good idea to look at the splines on the steering box though, they get into accidents and the steering box gets overlooked.
Old 05-21-2018, 06:25 PM
Motley's Avatar
Pitman arm, ball joints,
I started last year redoing the front end on my 94 2wd Base 22RE because the whole Assy was loose; you could hear it rattle going over tracks, curbs, etc... I've change the TREs and cross link so far. Upper ball joints and calipers are a problem though. I keep getting parts for something else. Ball joints are too long & calipers are a different brake line connection. Mine is a flare fitting. Does anybody still have info for the p/n and manuf for these? I would like to put it in service again. It will crank up and doesn't burn oil. 265k on it with a manual 5speed. Pretty much all original.
Old 05-23-2018, 10:20 AM
Robert m's Avatar
What about rebuilding your stock calipers? I know you can get kits and seals for them on rockauto.
And where are you getting these upper balljoints from?
Old 06-01-2018, 01:53 PM
Motley's Avatar
Ball joints came from Rock Auto but they were too long. Before that I tried to change out the whole upper A Frame assy and they sent me something else. Auto Zone had the rightside caliper which is the one with a broken bleeder valve that started the whole deal (Rock Auto had sent me calipers for something else that didn’t fit the file line). So since I have one new caliper I’ll get get another just to match. But the upper ball joints I wouldn’t mind changing out. That’s why I’m looking for a number that someone has used before, that worked on these trucks. I’m just probing around.
A2theK
01-03-2015 12:54 PM
broke1
12-01-2011 01:12 PM
balognapony420
11-07-2011 05:27 PM
korn111685
10-10-2009 08:10 AM
bradyal
10-30-2003 06:38 AM
Quick Reply: Can't Find 2WD Pitman Arm!
