Replacement fan blade wobbling
Old Jun 15, 2018 | 11:07 PM
Cj_sides's Avatar
A bolt was sticking of of the timing cover on my 1991 3.0 pickup as if the threads had been stripped and the bolt was able to move in and out of the cover without any resistance. Anyway, I made the genius move to ignore the problem and the bolt worked its way out and got in the way of the radiator fan and tore the darn thing off the clutch. I’ve since ordered a replacement an and put it on the truck and now the fan wobbles pretty violently. On closer examination of the fan I have noticed slight imperfections along the edges of the fan. The fan does not feel loose. Any idea on what this problem could be, besides a bad part, would be appreciated.
Old Jun 16, 2018 | 02:21 AM
wyoming9's Avatar
Red face
Bad fan Blade you have one of the lock washers on the wrong side
Those are my first guesses
Where did the fan blade come from
Old Jun 16, 2018 | 02:34 AM
Cj_sides's Avatar
I’m not sure if by lockwasher you mean the lock nuts (it may be possible that the lock washers fell off) but when taking off the fan I did not pay attention to which side the nuts were on. Also the nuts have sustained some Damaged nut (others have similar damage).
damage from the initial incident.
Old Jun 16, 2018 | 05:48 AM
wyoming9's Avatar
Red face
At one time in the past someone changed the hardware
It came original with a lock washer and nut
Are you sure the fan being destroyed did not damage the bearing in the fan pulley bracket ??
Bend the pulley itself ??
Old Jun 16, 2018 | 11:13 AM
Cj_sides's Avatar
yeah I have considered that possibility but The replacement fan is visibly not perfectly round so I’ll get another one of those to try out and go from there.
greenz02
Oct 18, 2011 12:14 PM
Buckmaster519
Jul 12, 2009 03:42 PM
crackerjack
Jan 21, 2007 12:16 PM
DOHCtorTHRUST
Mar 20, 2006 07:23 AM
mightyhye
Aug 23, 2005 08:25 AM
