Which temp sensor
Old May 6, 2018 | 05:43 PM
CDHyota's Avatar
Which temp sensor
1 in 3 trips to work (10 miles one way) temp gauge goes past middle where it normally runs and keeps going up . If I pop it in neutral ,shut key off then restart, then goes back to norm for the rest of trip.which sensor or other ideas
Old May 6, 2018 | 05:50 PM
RAD4Runner's Avatar
Which Escalade? Pls see signature.
Old May 6, 2018 | 05:54 PM
CDHyota's Avatar
Sorry 1990 4x4 ex cab 22RE 5 sp 90k actual miles
Old May 6, 2018 | 06:11 PM
RAD4Runner's Avatar
I suggest you put that info in your signature. We are not very nice to Escalade owners - LOL!
Could be many things.
This is for a problematic display: https://www.yotatech.com/forums/f116...ge-fix-271152/
Could be a bad sender that shows over-heat while engine is actually at proper operating temp. Need to take that out, inspect, clean, test. It's rather hidden (under the intake manifold below?)
Could be a problem with wiring?
Could be a problem with your thermostat where it is not properly opening or closing. You can easily take it out, inspect and perform a test.
Old May 12, 2018 | 07:59 AM
CDHyota's Avatar
Thanks I did flush coolant system when I bought truck and change thermostat , then changed it again when this problem occurred with a more expensive one . I did replace temp sensor you pointed out and thought problem solved ,then It did it again after a few trips . I'm sure it's not overheating just annoying now. Thanks again.
Old May 12, 2018 | 09:06 AM
RAD4Runner's Avatar
Then:
1) Test sensor signal per FSM, and
2)See link on problematic display above...
Old May 20, 2018 | 07:15 AM
CDHyota's Avatar
Replaced the temp sensor in manifold and that seemed to do the trick. Thanks again
brino1
Jun 25, 2012 10:47 PM
hackengineering
Jan 26, 2011 05:03 PM
americanmcss
Aug 26, 2010 11:22 AM
MIKEMOKAS
Nov 4, 2007 09:49 AM
Jonnym
Jun 17, 2006 03:40 PM
