EFI Fuse blowing
Old May 29, 2018 | 12:22 PM
DonnyD's Avatar
EFI Fuse blowing
Hello. I drive a 1993 Toyota 4Runner. i was driving to work, all highway miles, when i noticed my rpms were high. i tried making it to work, but about 30 seconds out of town, my rpms dropped to 0, and the engine stayed on. i assumed it had overheatted due to low coolant, but i filled the coolant and the engine just cranks. The EFI fuse had blown, i replaced it and tried cranking again. The fuse instantly blew, and no fuel would get to the engine. I checked my O2 sensor and the wire going up into the chassis looked good, so im not sure what would be causing the short in the fuse. i did check the main wire from the positive battery terminal to the fuse box, and it was quite melted, just the tape was melted though. not sure if this effects anything though
Old May 29, 2018 | 01:14 PM
RAD4Runner's Avatar
A problem well-stated is almost solved, but you have contradicting statements...
Originally Posted by DonnyD
...my rpms dropped to 0, and the engine stayed on.
... main wire from the positive battery terminal to the fuse box, and it was quite melted, just the tape was melted though...
What do you really mean? Melted wire or not? Running engine or not?
Yes, describing your problem well to people who may be thousands of miles away will affect how effectively they can help you. Pls see signature.
Old May 29, 2018 | 01:23 PM
DonnyD's Avatar
I mean the RPMs dropped to 0, but the engine stayed on, just like I said. Common for overheating as the engine wouldn’t want to burn out. The tape was a goo over the wire, i haven’t had time to check the wires internals.
Old May 29, 2018 | 01:34 PM
wyoming9's Avatar
Red face
The Tach Quit but the engine was still running ??
Transmission or Clutch slipping ??
Time to break out the Meter
Old May 29, 2018 | 03:55 PM
RAD4Runner's Avatar
If you haven't checked and don't know actual condition of wires, neither can we who are far from you. We could not help you.
Once you have the chance to inspect your engine and can put us in front of your truck, and let us know what you see, hear, feel,smell about it we'll talk. See signature.
swapped89
12
Dec 8, 2013 11:28 AM
91 4Runner
Oct 21, 2007 07:49 AM
gametom
Sep 27, 2007 10:06 PM
Connolly
May 15, 2006 03:37 PM
Churnd
May 18, 2004 09:02 PM
