top seed??
Old Sep 26, 2013 | 07:22 AM
kharris's Avatar
top seed??
I jut put a remanufactured 22re in my 86. I got lce headers, and inake, with a crane cam. my top speed is about 60 to 65 mph. I think I should be able get at least 70 out of it. I also have 32in. tires and 4.88 gears. I have the timing at 5 degrees btdc. any help would be awesome. thanks
Old Sep 26, 2013 | 07:34 AM
redbayredneck's Avatar
That doesn't sound right. I'm running stock everything and 31/10.50's on 4.10 gears and I can still hit 90 in my '85 22RE
Old Sep 26, 2013 | 08:34 AM
highonpottery's Avatar
what RPM are you at when you hit an indicated 65mph? since you have 4.88/32s, your speedo is reading slower than your actual speed - are you adjusting for this?
Old Sep 26, 2013 | 09:10 AM
Stetson_md's Avatar
My truck can hit mach1 just gotta be going down hill with a bit of a tail wind
snobdds's Avatar
I have a stage II engine from 22repreformance, with 4.11 and 235's.
Can do 80 in 5th gear and still have about 2000 rpms of pulling power left. It's scary to go much faster than that.
I can keep 70 in 4th gear going up a 7% grade, 8 miles long, with no issues.
Old Sep 26, 2013 | 09:19 AM
muddluvr's Avatar
hubs unlocked? in 2wd??
Old Sep 26, 2013 | 10:31 AM
I should note that I start losing oil pressure if I keep it At 90 for more than a short distance
Old Sep 26, 2013 | 10:34 AM
kharris's Avatar
don't have a tach so don't know rpms but in 2wd hubs unlocked pedal to the floor I can only get 60 to 65.
Old Sep 26, 2013 | 10:41 AM
osv's Avatar
osv
can you confirm that speed with a gps?
Old Sep 26, 2013 | 11:45 AM
Marc's Avatar
Without a Tach and a GPS it's really hard to diagnose.
Old Sep 26, 2013 | 01:06 PM
dswag's Avatar
Does it sound like its about maxed out by just listening to the engine? I can hit 75 without pushing it whatsoever and my motor has 300,000
pickle6415
Apr 14, 2021 06:20 AM
pickle6415
Dec 25, 2015 07:34 PM
LotOMiles
Sep 14, 2015 11:45 PM
highonpottery
Sep 14, 2015 12:46 AM
Boomer8404
Sep 10, 2015 09:01 AM
