Mystery Part, please help
Old Sep 28, 2013 | 07:59 PM
1stGenYoda's Avatar
I took my truck out and was washing out the engine bay to get some mud off. Im guessing a tad bit of water got in. As it started humming later while I was washing out underneath my 4runner. It hums with the truck off and on, I let it run for like half an hour to see if it would stop, well it didn't. so I disconnected the battery.
The guys at autozone didn't know what it was, and with a failed internet search im lost.
Here it is in the engine bay
Old Sep 28, 2013 | 08:08 PM
BigBluePile's Avatar
Electronic cruise control....?
Old Sep 28, 2013 | 08:29 PM
1stGenYoda's Avatar
I guess I should have gave more info. It is an 1986 4runner 22re. it doesnt have a cruise control
Heres more pictures, I hope this helps
Heres the side where the throttle cable and other wires go in
Here is the top cover taken off
Side cover taken off
Under it
Other side cover taken off
Old Sep 28, 2013 | 08:34 PM
Yes. Electronic cruise control.
80's Toyotas thru '95 came with, if equipt, vacuum actuated cruise control. That's after market.
Old Sep 28, 2013 | 08:39 PM
1stGenYoda's Avatar
Really?? then what would the humming be from? because when plugged in, it constantly hums. also does it need to be plugged in?
Any idea what an aftermarket cruise control button would look like?
Thank you
Old Sep 28, 2013 | 09:29 PM
I dunno. Look around in your cab.
Old Sep 29, 2013 | 04:28 PM
1stGenYoda's Avatar
Looked around and found nothing that even remotely looks like a cruise control
Also took the part out and took a hair dryer to it and put it back in and the humming stopped
Old Sep 29, 2013 | 04:41 PM
wiseguymmiv's Avatar
Thank you
Trace your wires running from that black box and see where they go. You might find the cruise control button, or at least where it is supposed to be.
Old Sep 29, 2013 | 04:43 PM
1stGenYoda's Avatar
I'll do that, cruise control could come in handy
Old Sep 29, 2013 | 04:50 PM
Definitely.
I recently traced the wires on several of my aftermarket mods (Hella driving lights and cab switch, external reverse lights and cab switch, air horns) and labeled each with tape and a paint pen, for ease of repair, etc. As much as we mod our trucks, the wires get to be a jumbled mess without labeling.
Good luck!
Old Sep 29, 2013 | 06:05 PM
1stGenYoda's Avatar
Thanks for the advice
88sasturbotoy
Jan 30, 2026 01:57 PM
Yota.Jay
Jul 23, 2015 08:08 PM
Fundy Rider
Jul 16, 2015 01:35 AM
Odin
Jul 15, 2015 09:28 PM
akaphilly
Jul 9, 2015 02:34 PM
