Tps issues
Old Sep 22, 2013 | 08:49 AM
kharris's Avatar
Tps issues
Upon puttining in a new tps I can't get the correct ohm reading at wot. Fully closed I got .8 but at wot I get 2.6. My manual is calling for 3-10 at wot. I tried to adjust the set screw but to no avail, so I took the tps back to autozone they tested it an said it was fine. Please help
Old Sep 22, 2013 | 04:29 PM
maco35's Avatar
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Sep 22, 2013 | 05:18 PM
scope103's Avatar
Did you try measuring the resistance VTA-E2 with the TPS off the truck? If you can get the full spec resistance (3.3k-12.1k ohms), then the problem is not with the TPS, but you may have something bent in your throttle linkage.
What happened at Autozone? Did they measure the part with an ohmmeter?
Old Sep 22, 2013 | 10:04 PM
Gevo's Avatar
I would check the wiring coming to the TPS to make sure it wasn't being 'slightly' shorted somewhere along the line... I'd check them for continuity and resistance. I believe you can test the voltage coming to the TPS. I believe there is a tutorial, check youtube.
Old Sep 23, 2013 | 04:18 AM
oldblue's Avatar
i'd like to know how autozone was "testing" it.
Old Oct 26, 2013 | 07:36 PM
Yotapower89's Avatar
dont go to auto zone. they only know what the computer tells em. Napa is your best bet. or toyota.
Gone Fission
Jan 12, 2023 10:34 AM
Blamalam
Mar 12, 2022 07:34 AM
Sleaker
Aug 26, 2020 06:03 AM
129Creepin
Aug 5, 2015 10:12 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
