Axle chunk question!
Old Oct 15, 2013 | 08:28 AM
YotaCurly's Avatar
I have a buddy that has 5.29 gear ratio chunk in a 6 lug solid front axle, would this chunk also work in my v6 6 lug rearend I believe his is a 87 axle??! Any help on this one guys !?
Old Oct 15, 2013 | 08:36 AM
coryc85's Avatar
I think the short answer is yes it will fit. Being that his is in the front of an SFA truck, we know it must be an 8" ring gear, so it will go right into your 8" rear axle. The one question I would have is whether it is a V6 version of the diff or a 4cyl version. Most would say the v6 version is stronger. You can identify the diff type by the housing. Up to you if that strength difference really matters to you, and one more thing, just my .02 here, but 5.29 seems like a steep ratio for 3.0 and 33" tires.
Old Oct 15, 2013 | 08:47 AM
YotaCurly's Avatar
I appreciate the info I thought all v6 diff came with 6 lugs and the 5 lugs came with the 4 cylinders ?? And it's a automatic btw that's why I'm going that steep
Old Oct 15, 2013 | 09:58 AM
93Xtra-Cab's Avatar
It's not 6 cylinder vs/ 4 cylinder that determines whether its a 6 lug or 5 lug. It's 2wd vs. 4wd. 4wd are 6 lug, 2wd are 5 lug.
Old Oct 15, 2013 | 10:20 AM
YotaCurly's Avatar
But would a 4 cylinder diff work in a 6 cylinder diff??
Old Oct 15, 2013 | 10:52 AM
vasinvictor's Avatar
Absolutely.
Old Oct 15, 2013 | 01:31 PM
YotaCurly's Avatar
Anyone have any luck running 5.29's with 33's on a v6 with an auto
88sasturbotoy
Jan 30, 2026 01:57 PM
oldirtydirt
Feb 23, 2020 09:30 AM
polo451
13
Nov 20, 2016 07:49 PM
delmert
Sep 30, 2015 04:34 PM
Backcountry411
Jul 24, 2015 08:06 AM
