Couple of rebuild questions
Old Sep 25, 2013 | 10:14 PM
JakeMcGuire's Avatar
I have a 92 Pickup with the 22RE that is fixing to get rebuilt. Unfortunately due to a busy work schedule I don't get to try this myself. I've never rebuilt one anyway so maybe its for the best. But right now there is a few different possibilities for now, all depend on what the mechanic says when he tears it apart tomorrow.
The motor threw a rod is the reason for the rebuild. So here are my options:
Worst case, messed up block and head, in which case i'll be buying a used motor and a rebuild kit. So not many questions there.
Best scenario; no damage to block or head and just a rebuild kit and crank kit. Highly unlikely i suppose but nice to think positive.
Here's where i have questions, if it were to only damage the block, I've found a .40 over block cheap. I know i would need bigger pistons, which engnbldr offers in a kit, along with the bigger cam i think i'd like. If I get the bigger pistons will I need a different crank kit for it? Or does the regular one work?
I'll know more details tomorrow and will update accordingly, just wanted to get a jump on it if possible. Also is the engnbldr kit pretty good or should i look elsewhere?
I don't know a whole lot about all this but hope to learn.
Thanks in advance,
Jake
Old Sep 26, 2013 | 01:15 AM
wyoming9's Avatar
Red face
Your crank is your crank piston size has nothing to do with it.
However being that you may have spun a rod bearing depending on how bad that journal is damaged you may need the crank turned and then need oversize bearings .
Then if the damage is to bad time for new crank one never knows till it is all apart.
Old Sep 26, 2013 | 01:34 AM
Thanks for the reply, all a new experience for me and I appreciate it. I'll be sure too put what he says tomorrow so I can get a little more info and advice. Thanks again,
Jake
Old Sep 26, 2013 | 01:36 AM
Later today rather, night shift has me all messed up haha
Old Sep 26, 2013 | 11:51 AM
osv's Avatar
osv
since you are having someone else rebuild it, these questions are not necessary, because your mechanic will be sourcing the parts.
Old Sep 26, 2013 | 04:46 PM
Got some good news back, didn't really mess anything up too bad. Rebuilding with a kit, new crank kit, oil pump, water pump, and thermostat and should be good to go. The truck has had a new timing chain put in with metal guides that are still in good shape. Parts came out to just under $600, and for another $800 he pulled the motor, took apart, rebuilding it, putting it back in and putting my header on. I didn't think that was too bad, especially since i don't really have any other options.
Thanks again for all the help.
Any advice on break in for this new motor?
bigjstang
Jun 2, 2025 03:56 PM
coleypull15
Nov 3, 2015 07:41 AM
DrZero
18
Jul 24, 2015 11:31 PM
icentropy
Jul 14, 2015 10:23 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
