No Fuel
Old Sep 23, 2013 | 10:00 PM
larry1845's Avatar
No Fuel
Had to put a head gasket on my 95 toy 4x4 22re.Got it all back together and started to fire it u and nothing. Getting fire to the plugs but not starting. Check fuel to the fuel filter and its there but either the injectors aren't opening or the fuel not getting to the injectors.
First thing I thought was maybe I left a plug unplugged but I don't know where to look. Can anyone offer me some advice? I did check all fuses and all are good. I have fuel to the filter and its coming out the other side of filter. Was going to check the fuel rail in the morning see if its ok.
Old Sep 23, 2013 | 10:59 PM
Gevo's Avatar
I'm not familiar with these engines, but if I suspected a plug, I would start by following the engine harness. If everything is plugged in and you are sure the fuel is there... I would reset the computer.
BUt wait for someone with more experience with these engines to give advice. I'm here avoiding sleep
Old Sep 24, 2013 | 09:32 AM
Terrys87's Avatar
Are your injectors firing? Here is my $3 noid light. The light will only allow current to flow one way, so it is possible to have your connections to work and it not light up. If that is the case, just reverse the leads. NOID Light>> https://www.yotatech.com/forums/f116...t-22re-270857/
If injectors are not firing, here is some steps that I went thru to get my injectors working>>> https://www.yotatech.com/forums/f199...l#post51897320
wafoogalla
Nov 2, 2016 11:02 AM
daddio
Aug 9, 2015 07:17 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Fundy Rider
Jul 16, 2015 01:35 AM
shisha1999
Jul 13, 2015 11:09 PM
