2.4 sputtering/rough running at low idle
Old Oct 8, 2013 | 04:02 PM
PFC4311's Avatar
It happened after I got it stuck mudding, we pushed the engine hard trying to get it out. Started leaking a little oil from the valve cover, and the next day it started running real rough and sputtering at low idle. Always happens when stopped or just coasting in neutral. I replaced the valve cover gasket and pcv which stopped the oil leak but the sputtering hasn't ceased. I'm not sure what the problem is? I checked the plugs and made sure they weren't fouled, no oil in the dist cap, no black or white smoke coming from the tail pipe. Any suggestions on what it could be or what I should check next? My specs are 2.4 with about 235,000 miles, 4x4, manual tranny
Old Oct 8, 2013 | 04:15 PM
rworegon's Avatar
Did you get water into the air cleaner and intake?
Old Oct 8, 2013 | 04:20 PM
PFC4311's Avatar
Hmm didn't think to check because I didn't get too deep in the water, I'll see tomorrow.
Old Oct 8, 2013 | 04:23 PM
rworegon's Avatar
Also, check all vacuum hoses and wiring connections.
Old Oct 9, 2013 | 02:49 PM
PFC4311's Avatar
Checked the air filter and lines and it's all good. I ran a compression test and all the cylinder's except one averaged around 145-150 psi, my last cylinder read a 120 psi reading. How can I tell if it's bad piston rings, valve seats, or a cracked head gasket, or possibly some other reason for that cylinder's low compression? Also I adjusted my idle up a bit and now it's running much better.
Charecter1
Nov 6, 2023 10:08 AM
jbv808
Aug 6, 2021 04:47 PM
icentropy
Sep 16, 2020 02:47 PM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
