compression test
Old Oct 18, 2013 | 11:17 AM
madfie's Avatar
compression test
hey all, I did a compression test other day and got 175 in all 4 cylinders. I didn't realize, didn't have fsm yet, do now, that the engine was supposed to be warm and to pull the efi fuse. Will this throw my numbers way off? Gonna redo it tomorrow when I get home. Also picking up leak down tester. also doing it by myself so should I hold the gas pedal down on the efi?
Old Oct 18, 2013 | 11:38 AM
SoCal4Running's Avatar
Warm engine might increase the numbers just a little and not disabling the EFI might also a little bit.
Yes you want to wedge the throttle open so the TB/Butterfly is open to allow maximum air thru.
I doubt you'll see very much difference redoing the test and since your numbers are even I'd be fine driving it as is until next tune up/service.
eggens
Oct 27, 2015 03:14 PM
_Nicco_
Sep 21, 2015 03:06 PM
Yont283
Sep 20, 2015 10:56 PM
Yont283
Sep 12, 2015 10:03 AM
Boomer8404
Sep 10, 2015 09:01 AM
