steering wheel swap
Old Oct 12, 2013 | 10:58 AM
Aquatic Escape's Avatar
steering wheel swap
I have a 90 4runner with cruise control in steering wheel that needs to be replaced. I have no use for the cruise control. I bought a Grant wheel, but the adaptor won't work. Does anyone know what i can do to replace it without cruise. I pulled the wheel hoping that I just had to tie off some wires, but the wires come into a plug and the plug is in the way of the adaptor. The plug looks to be all part of the turn signal adaptor. Can I swap out the turn signal adaptor with one from a non cruise? or is there an easy way to mod it and make it work.
Old Oct 14, 2013 | 02:22 PM
Slowey23's Avatar
the black ring that has the plug coming out of it is removable, remove it then your adaptor should have a couple small holes in it to line up with the 2 pins on the turn signal cancel, line those up which should be 12 oclock and 6 oclock and it should be all good, no cruise though, I started doing that the other day but im gonna rewire the cruise so I put the original wheel back on.
mlavery85
Jul 12, 2015 10:33 AM
jon.r
Jul 11, 2015 03:34 PM
skoti89
Jul 6, 2015 07:45 PM
