3VZE Transmission Squealing/squeaking
Old Oct 9, 2013 | 06:46 PM
Markarino's Avatar
Hey guys just got a new noise coming from my Pickup. It's some sort of squeaking/squealing from the transmission I believe, seems to be from there when I get underneath. Now I just recently replaced my flywheel and clutch with the marlin crawler set and I also converted over to the redline fluid just to keep you guys up to date. Anyway this squeak likes to come and go, but when it does stay consistently it goes away as soon as i touch my pedal, and I mean the slightest touch makes it silent. Any idea? Thanks
Old Oct 9, 2013 | 06:52 PM
Toyota~Boy's Avatar
Throw out bearing has got moisture in it and caused the bearings to develop corrosion. In return the throw out bearing is noisy as it spins on the tranny shaft. Once it comes in contact with the pressure plate it gets pressure against it thus eliminating the squeal.
Old Oct 9, 2013 | 07:04 PM
Markarino's Avatar
I replaced that stuff a month ago, if that is the case your pretty much telling me I'll have to replace the throw out bearing in order to eliminate the noise completely?
Old Oct 9, 2013 | 07:09 PM
Toyota~Boy's Avatar
I mean yeah if that's the case. But you gotta think I'm telling you the first thing that popped into my mind from your description. I may be incorrect ya know. Try getting some spray lubricant and spraying it into your transmission were the clutch fork comes out the bell housing. Try not to spray the clutch disk. This may fix it bud.
Old Oct 9, 2013 | 07:15 PM
Markarino's Avatar
Of course, your reply was the quickest so I'll wait to see what everybody else can bring to the plate, I'll give that a go.
Old Oct 9, 2013 | 08:07 PM
vital22re's Avatar
totally a bro
did you grease the throw out arm pivot point and replace the pilot bearing?
Old Oct 10, 2013 | 03:12 AM
Markarino's Avatar
I replaced the pilot bearing, don't recall greasing the arm
crammit442
7
Nov 29, 2017 12:30 PM
Hugh_Mann
Aug 31, 2015 04:02 AM
duncanmc
Aug 19, 2015 03:13 PM
Wooddmiester
Aug 11, 2015 07:42 PM
