is this differential normal? (pic)
Old Mar 1, 2009 | 11:17 AM
toyNG's Avatar
Does this diff look normal? Specifically, the area pointed to. I'm considering buying it.
Old Mar 1, 2009 | 12:05 PM
Matt16's Avatar
Yes, that's a diff from a 4 cyl truck and that divot there is where the dowel pin goes in to hold the cross-pin in place.
Old Mar 1, 2009 | 12:13 PM
toyNG's Avatar
cool. that's the answer I was hoping for. thanks for the reply.
Old Mar 1, 2009 | 12:55 PM
Matt16's Avatar
When checking the diff, the ring (big) gear should spin smoothly with a little resistance. When you rock the ring back and forth, it will make a tiny "clack" when changing directions, you should barely be able to see the play that accounted for that noise as its should be about 0.01" for a used diff. Make sure the faces of the gear teeth are smooth as well.
jerusry
Oct 19, 2015 05:28 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
ripp96
Jul 31, 2015 11:14 AM
ripp96
Jul 25, 2015 02:32 PM
