'91 22REC 2WD oil pan OUT!
Old 02-25-2009, 07:27 PM
mightyjak's Avatar
As in: I need to get it out. After 280,000 grimy miles.
Low comp in #1 cylinder, pulled head for new gasket, pulled face for timing chain and dampners, need to pull oil pan to hone #1 cylinder and rering. I must get the oil pan out of it's cage. Tried jacking engine up, close but no cigar. Also tried removed castle nuts on front steering link but how can I parts to separate? Is it a matter of a puller for the idler and Pitman arm? or should I be able to pull things apart without that?
So close.....
Thanks for the help.
Jeff
Old 02-25-2009, 07:33 PM
ozziesironmanoffroad's Avatar
why not pull motor and do a rebuild?sounds like ur halfway there anyway...
Old 02-25-2009, 07:49 PM
mightyjak's Avatar
Short on money and long on time. Truck is great otherwise. I know I should rebuild, but that's not an option right now. Unless it's less than $400 dollars.
Any thoughts on the oil pan?
Old 02-25-2009, 07:52 PM
abecedarian's Avatar
2wd?
pull the little crossmember between the frame rails and the sway bar then the idler arm on the passenger side.
Should be enough to drop the pan- worked for me on my 91.
Old 02-25-2009, 08:12 PM
mightyjak's Avatar
I have the crossmember out and have removed castle nuts across the front. Am afraid to put too much monkey on it as things have a way of breaking. I tried block of wood and hammer, but to no avail. Do I need to remove steering dampner as this puts pressure on the steering link? How easily should the steering link come out?
Book says disconnect at idler and pitman arm and lay steering link out of the way to remove the pan. That's where I'm stuck.
Old 02-28-2009, 06:04 PM
mightyjak's Avatar
Pan never came out, but the engine did.
09-04-2015 09:27 AM
thefishguy77
07-30-2015 10:59 AM
irritech
07-27-2015 05:15 PM
toofly1999
07-25-2015 07:09 PM
colasurdo
07-16-2015 11:37 AM
Quick Reply: '91 22REC 2WD oil pan OUT!
