body lift help
Old Feb 23, 2009 | 01:28 PM
gary96360's Avatar
body lift help
i bet this topic has been to death many times. i have a question for you guys with a 3 inch body lift that did stuff so their shifter will stay in gear. i have the sr5 style truck so the shifter boot is completely different, made of leather or vinyl. what are the tricks so that the truck can shift properly? ive searched and cant find people that showed pics what they did to their shifter.
Old Feb 23, 2009 | 01:38 PM
Dirt Master80's Avatar
shifting
your shifter is probably hiting the sheet metal under the boot and will require a little triming, you might also have to move the boot around to get it to work. your other option is to cut and re-weld the shifter in a position that allows it to work. the hard core thing to do would be to lift your motor/trans/transfercase up, it would give you more ground clearance at the t-case and fix your problem.
Old Feb 23, 2009 | 01:57 PM
anthony1's Avatar
You can also contact Marlin. He made me a short-shifter that works with my 2" body lift.
Old Feb 23, 2009 | 02:55 PM
Tubbyfatty's Avatar
short shifter for the regular gears? Pics? lol.
Old Feb 23, 2009 | 03:04 PM
anthony1's Avatar
It's more like short-throw shifter....don't have to get up to shift to 5th gear.
Old Feb 23, 2009 | 03:15 PM
Tubbyfatty's Avatar
Oh lol, gotcha.
Old Feb 23, 2009 | 04:13 PM
space-junk's Avatar
take off the leather boot and the plastic center console around it and you will see that you have the same rubber shift boot as the regular guys...
Old Feb 23, 2009 | 07:41 PM
rock slayer's Avatar
with a 3 in body lift on a 2nd gen runner what else do i need to do besides spacers???
sorry to steal the light but i reaaally didn't wanna start another post (should i have??)
Old Feb 23, 2009 | 07:43 PM
waskillywabbit's Avatar
IF you guys want to do large body lifts, go to 4crawler.com and research his website. He has all the stuff you need for the big body lifts, bumper brackets, radiator brackets, shifter extensions, etc.
It's all there. Go read.
Old Feb 23, 2009 | 07:48 PM
yeah i see it my last truck was a 91 standerd cab with a 3 in body lift and didn't need any of that...maybe a bumper bracket???.... yeah it woulda been nice but...do i need them??
Old Feb 23, 2009 | 07:58 PM
Every truck is different...but with shorter body lifts they are all the same...that is why I deal only with 1" body lifts...makes it simple.
Old Feb 23, 2009 | 08:21 PM
gary96360's Avatar
if im doing a body lift i might as well do a big one hha.
Old Feb 23, 2009 | 08:24 PM
Yep, some folks do big body lifts, nothing wrong with that although personally I don't. I stick with a 1" body lift cause I just want some extra body to frame clearance for issues like plumbing, wiring and dual cases. Makes some things much easier to work on and with.
Old Feb 23, 2009 | 08:42 PM
Mic09dcsm's Avatar
OR you could do the perfect Bl, the 2", not too little, not too much, just right. Not only wiring but room for when you decide to design a sub box that works well and isn't in the cab except for the cubby area, hiding train horns, mounting the top eyelets of shock higher, for when you do the 4.3 or 3.4 swap, etc etc.
Old Feb 23, 2009 | 10:55 PM
Jay351's Avatar
I cut and welded in the 3" extensions as per the Performance accessories instructions (at the base, befor they bend). I then bent the shifter slightly up and to the left to clear the t-case shifter.
To get all my gears (I was having issues with 4th and reverse) I simply inverted the inner hard rubber boot. The pleather sr5 boot covers it all back up Been working flawless for almost 2 years now..
Old Feb 23, 2009 | 11:03 PM
IngSoc's Avatar
I got a 5in sus lift, and a 3in body lifet with 33`s I want to get a set of 35`s for offroading. Would you guys suggest taking it completely off or cutting the pucks in half and doing a 1.5in? Where would I get new rubber bushings? Sorry toask in your thread but didnt want to start a new one.
Old Feb 23, 2009 | 11:04 PM
Jay351's Avatar
keep it like it is, unless you want to beat/trim for tire clearance.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
upongame619
Aug 1, 2015 12:12 AM
Cabell
Jul 24, 2015 12:14 PM
Backcountry411
Jul 24, 2015 08:06 AM
