22re afm test
Old Feb 23, 2009 | 07:02 PM
sas'd22re's Avatar
22re afm test
i tested my afm and found that one of the readings between E2-THA was out. would this one thing throw off the afm? im a rookie when it comes to multimeters and afm's and hope i am doing things right. i checked it twice and got the same readings
should be between my readings
E2-VS 20-400 105
E2-VC 100-300 180
E2-VB 200-400 280
E2-THA 4K-7K (around 5*celsius outside) 3100 (i think)
E1-FC infinite infinite (i think, multimeter stayed at 1)
any help would be great
Old Feb 23, 2009 | 08:08 PM
sas'd22re's Avatar
are all 22re afm's the same? i have another one but its off of an 89 and not 100% positive it'll work. anyone?
Old Feb 23, 2009 | 08:36 PM
BigBluePile's Avatar
E2-VS 20-400 105
E2-VC 100-300 180
E2-VB 200-400 280
stayed at 1)
any help would be great.
Man I could SWEAR I've seen this post before...
Look here:
http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
Old Feb 23, 2009 | 08:38 PM
sas'd22re's Avatar
thats the site i used to check it. just not sure if that one reading would totally mess it up or not.
Old Feb 23, 2009 | 08:47 PM
abecedarian's Avatar
that's the incoming air temp reading. the ECU's going to think the incoming air is warmer than it really is so the mix may be slightly lean. it's not such a big deal as it sounds. as long as the ECU isn't maxed out adjusting the fuel mixture, the O2 will signal the condition and the ECU can compensate.
Old Feb 23, 2009 | 08:54 PM
sas'd22re's Avatar
i see. thanks. so as long as my o2 sensor is working properly i should be set? are 22re afm's intrerchangable? i have one from an 89...will it work on my 86?
88sasturbotoy
Jan 30, 2026 01:57 PM
RatOmeter
Oct 22, 2015 03:17 PM
mtb_taco
Oct 5, 2015 04:36 PM
crashburnoveride
Aug 28, 2015 09:20 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
