Swapping in Tilt Steering into a 94 truck
Old 02-28-2009, 06:13 AM
metalhed's Avatar
Greetings My 16yo son recently bought a 94 Pickup. Super nice truck but he is pushing 6'3" and the steering wheel is very tight to his legs.
Has anyone swapped in a tilt steering column from another truck or 4 runner?
If so what year, parts, cost etc...
I have checked with a few Toyota junkyards and they were not much help. Bodyshops zero info.
I want see if this is even possible.
Old 02-28-2009, 08:00 AM
Cyberman's Avatar
You should be able to swap a tilt column from any 89-94 pickup. Just remember to get the keys for the ignition with it, or you'll probably need a locksmith to swap out the cylinders. I'm 6'1", and have tilt. But the extra cab is what helped me with the leg room. Those standard cabs are a little tight.
Old 02-28-2009, 08:10 AM
mt_goat's Avatar
Mine came with tilt, maybe its an SR5 thing.
Old 02-28-2009, 09:23 AM
SpecialScottie's Avatar
I swapped in a tilt wheel in my 85. Simply unbolt the old one and bolt the tilt steering column right in
Old 10-27-2009, 04:49 PM
turbowhine's Avatar
I've been thnking about swapping in a tilting steering wheel too. From a 93 4runner into my 91. Can anyone say a little more about the ignition cylinder? Would I have to use a different key, are there any options for switching all of it?
Old 10-27-2009, 04:51 PM
abecedarian's Avatar
You'd have to have the tilt re-keyed to match your old key or re-key everything (doors, etc). The lock cylinders on the tilt columns are different than the standard column.
GreenLion
06-07-2021 10:49 AM
voiddweller
19
05-02-2016 09:10 PM
1badyota350
06-28-2015 06:50 AM
Ott47
06-26-2015 05:21 PM
paxanders
06-21-2015 06:29 AM
Quick Reply: Swapping in Tilt Steering into a 94 truck
