22RE crank but no start - got fuel and spark
Old 03-01-2009, 06:51 AM
scharp's Avatar
i have a problem. i got a 22re that wont start. i checked fuel and spark i got both. it will crank but no start. what do i need to check
Last edited by waskillywabbit; 03-01-2009 at 07:13 AM. Reason: Title clarity will provide faster help with questions
Old 03-01-2009, 07:16 AM
waskillywabbit's Avatar
Welcome to Yotatech.
Do you have a FSM? If not, there are some troubleshooting tips there.
Try this link and see if you can find something in the FSM.
https://www.yotatech.com/forums/f128...-years-156128/
Good luck and please update when you find the problem as that helps future users with the same issues.
Old 03-01-2009, 07:38 AM
abecedarian's Avatar
have you checked that the fuel injectors are getting the signal to fire?
have you checked that the distributor is installed correctly? ...with the rotor pointing at the proper cylinder?
Old 03-01-2009, 08:08 AM
scharp's Avatar
see i know we have fuel to the filter, but i havent checked yet to see if its at the rail or checked the signal. also we jumped the diagnostic port and got 8 flashes, a pause then 11 flashes, a pause then 2 flashes
Old 03-01-2009, 08:11 AM
What year is the truck?
Old 03-01-2009, 08:24 AM
scharp's Avatar
its an 87
Old 03-01-2009, 08:45 AM
arizonaguy's Avatar
22re no start
do you have compression?????
Old 03-01-2009, 08:49 AM
is the air flow meter hooked up, physically and electrically?
2 and 8 point at the air flow meter, 11 points at the throttle position sensor
Old 03-01-2009, 09:53 AM
scharp's Avatar
yea we have compression, the air flow meter is hooked up
Old 03-01-2009, 10:16 AM
Have you been working on the engine- rebuilding or replacing it? What work's been done on it recently?
Here's the codes breakdown-
2: air flow meter signal: VC or E2 open; VS-E2 or VC-VS shorted
8: intake air temp sensor: THA open or short
11: neutral safety switch is on, or TPS IDL signal is off when diagnostic terminal is shorted.
here's troubleshooting of the AFM: http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
here's troubleshooting of the TPS: http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old 03-01-2009, 10:41 AM
scharp's Avatar
well this is a standard so it just has a clutch switch and it should start right
Old 03-01-2009, 12:17 PM
the code means the clutch was depressed and the switch was on when the jumper was inserted
OR
the TPS IDL (idle contacts) were not closed when the jumper was inserted
Old 03-01-2009, 01:06 PM
scharp's Avatar
so your saying that i might not have to pay attention to that code
Old 03-01-2009, 01:09 PM
xzyragon's Avatar
is it timed right?
is it at TDC 1 when you start it?
Old 03-01-2009, 01:32 PM
scharp- disconnect the battery for a few minutes to clear the codes then put the jumper in and go turn the key to 'on' (don't start it) and see if anything comes up. If it does, then that may be something to worry about.
and yeah, I asked earlier but didn't get an answer and xzraygon brought it back up- have you checked the distributor?
Old 03-01-2009, 02:25 PM
scharp's Avatar
yea i checked the distributor. but i did some volt testing and the tps fully open is supposed to have 4 - 10 volts and it only and 1.7v i think i found the problem. would that cause it not to start
Old 03-01-2009, 03:16 PM
well... yeah it could.
so, with the #1 cylinder at TDC, both #1 intake and exhaust valves open, the rotor is pointing at approximately 10 o'clock?
Old 03-01-2009, 03:25 PM
scharp's Avatar
yes everything timing is good. how would the tps cause it not to start?
Old 03-01-2009, 03:30 PM
before we go into that...
you said the TPS tested bad. What terminal tested bad? VCC, VTA, IDL, E2? What was the battery voltage during the tests?
Old 03-01-2009, 03:34 PM
While waiting for that... do you have continuity between E2 and IDL terminals (3rd and 4th from the top) with the TPS installed and the throttle closed?
(those are the ones that will throw the code)
Quick Reply: 22RE crank but no start - got fuel and spark
