86 pickup running wierd
Old Feb 27, 2009 | 10:48 AM
86 SR5 4x4's Avatar
The truck runs fine when I first start it up being cold. After it warms up I shut it off for about an hour then restart it and it starts acting up. If im sitting still at idle and turn the wheels left or right the truck will start popping and backfiring. If it doesnt start acting up immediatly ill turn the lights on and it will do it. Whats funny is when I flip the lights on the motor cuts back for half a second. This problem also occurs out of nowhere when im at speed and the tach will start bouncing around and the engine will pop and backfire horribly. I have replaced the plugs, wires, cap, rotor, battery and borrowed the coil and 02 sensor from my 4runner. I think the sensor from my 4 runner is bad too because it seemed to make it run worse. I hate to buy a sensor have something else be wrong. Anybody else have this problem im stumped?
Old Feb 27, 2009 | 12:31 PM
86 SR5 4x4's Avatar
Just replaced the 02 sensor and the problem is still there.
Old Feb 27, 2009 | 01:01 PM
toyota4x4907's Avatar
Doesn't the power steering get "boost" from the engine? Maybe you have some vacuum leak somewhere in that system.
Get your alternator tested. It might be going bad. make sure none of the wires leading to any of the lights are shorting.
Old Feb 27, 2009 | 04:02 PM
86 SR5 4x4's Avatar
Ok so now it only does it with the lights on and the 02 sensor seemed to help but the problem still comes up.
Old Feb 27, 2009 | 04:10 PM
abecedarian's Avatar
I'd be checking all the engine grounds and the area around the coil / igniter for issues such as poor/corroded connections, loose wires, wires that have come loose from plugs, etc.
Have power steering (?)- make sure that there is no fluid in the two vacuum lines that go between the throttle body / intake and the power steering pump do not have any fluid in them. If so, the valve on the power steering pump will need replaced.
Old Mar 1, 2009 | 08:15 AM
86 SR5 4x4's Avatar
Ok so I replaced the ignitor and no difference. Also the lines going from the intake to the power steering pump have been deleted.
sonic concepts
Aug 16, 2025 03:13 PM
77lubr
Jun 17, 2016 05:55 PM
serenity03k64
Jun 27, 2015 07:59 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
ibayne
Jun 26, 2015 06:30 AM
