Couple of tech questions
Old Feb 27, 2009 | 01:53 PM
Fyrdawg5521's Avatar
Question Couple of tech questions
My apologies to the group. I didnt read the part about labeling the threads with specific information before I posted. Mia Culpa! But I do have just a couple of questions, one technical on transmissions, the other on a noise issue with my power train.
1. I have an 88 std 1/2 ton with the gas carb 22R, RN50 body style. It has a 4 spd trans, which I think is a G series. But Im not sure where to find that info. And I seriously want to swap it out for a 5 spd to boost my mileage and reduce wear on the engine. The truck is used mainly as a commuter and light-hauler. Any advice on compatible transmissions?
2. When accelerating from a stop, I hear a single ping coming from the rear of the truck. I've visually inspected the u-joints, and checked for any excessive play in the shaft and differential. I've put the truck on jacks to try and pinpoint the noise, but I cant repdroduce it unless there's a load on the drivetrain.
Thanks in advance for any help!
JC
Old Mar 4, 2009 | 07:03 PM
ffryno13's Avatar
you can call the junk yard and find a 5 speed form another 4x4 4cly you might have to cut a bigger hole in the floor board. i did a 5speed swap in a 85 2wd but your going to have an extra T-case go to marlin or trail gear and do dual T-cases.
2. and for the ping i have no idea. it might be your spare tire chain or empty beer cans in the back. what i would do is just start wiggling things see if it fixs your issue
Old Mar 4, 2009 | 07:09 PM
abecedarian's Avatar
/me not being a transmission person, can't help you there, but if you look for a 5sp for a 2wd truck (you are 2wd, right?) you should find what you need.
as for 'pings' in the back, the first place I'd be looking at is the u-joints. If replacing those (they're not that expensive) doesn't fix the problem then maybe the rear axle is 'wrapping' up a little bit causing the overload leaf to tap on the other springs...?
Could also be dry spring hangers / bushings too.
I suppose it could be possible that one of the rear brakes are hanging or the springs within are hanging... so maybe that's somewhere else to look.
thefishguy77
Jul 30, 2015 10:59 AM
DrZero
18
Jul 24, 2015 11:31 PM
icentropy
Jul 14, 2015 10:23 AM
Jnkml
Jul 6, 2015 01:20 PM
