91 toyota pickup air intake
Old Feb 26, 2009 | 12:47 PM
Tick's Avatar
I was wondering if anyone has seen or tried this ?
Is it worth the money ? and do you gain the HP's?
Air intake
Old Feb 26, 2009 | 12:54 PM
abecedarian's Avatar
saw the pic... where does the PAIR system get it's air from with that intake?
and word has it that you'd be better off doing the afm/battery swap
Old Feb 26, 2009 | 01:00 PM
yotakid825's Avatar
I think a few people on here have that one(I could be wrong). I made my own, I won't post a pic because it's pretty ugly, but I didn't really feel an increase in HP and maybe the truck get .5 mpg better.
Other than looking cool and making noise, I don't think it will really do anything. But it's only $50 so if you want it, go for it.
Old Feb 26, 2009 | 01:30 PM
xzyragon's Avatar
i have a similar setup:
u recieve more of the potential HP (not that big of a difference) but it sounds a little better. The only reason I would really recommend getting one is if you have no other choice. My airbox was smashed, so it was cheaper to go aftermarket.
For $51 if it includes AFM, thats pretty cheap. Even if it doesn't its still a pretty good price. Just make sure that either it comes with or u can make brackets to mount it.
Old Feb 26, 2009 | 01:37 PM
hillbillydeelux's Avatar
tried it and didnt like it so i went with this:
Old Feb 26, 2009 | 01:39 PM
highonpottery's Avatar
might be a stupid question, but when you do this type intake crossover pipe mod, what happens to that other hose that connects to the airbox?
Old Feb 26, 2009 | 01:44 PM
oops sorry double post bahhhhh
Old Feb 26, 2009 | 01:45 PM
You must be referring to the PAIR air supply.
I've asked myself that same question....
Old Feb 26, 2009 | 02:00 PM
xzyragon's Avatar
i do believe ur referring to this:
Old Feb 26, 2009 | 02:04 PM
yeah, I could see that working... but with the battery / afm swap mod like hillbillydeelux posted a pic of there's no mention of it
Old Feb 26, 2009 | 03:13 PM
turborich's Avatar
It's up to you but I wouldn't run that cone filter under the hood. All it will do is suck up hot air & decrease your HP. Those things are junk unless you mount it out of the engine bay. There are better options.
Old Feb 26, 2009 | 03:43 PM
Youngblood's Avatar
Uhm not really? as long as you dont put it super close to the headers you'll be fine while youre driving
Old Feb 26, 2009 | 03:45 PM
xzyragon's Avatar
ive found that the engine responds better with the cone filter as opposed to an airbox...
also, it breathes through a small hole in the sheetmetal up front by the headlight.
Ideally would be a scoop from the outside, but this is a pretty good alternative.
Old Feb 26, 2009 | 04:55 PM
Junkers88's Avatar
I ran mine under the hood and have no issues.
Old Feb 26, 2009 | 06:27 PM
mine didnt have one... maybe it was rigged when i got it?
Old Feb 26, 2009 | 07:22 PM
4x4cody's Avatar
i got one of them intake thingys
adds some noise to your ride maybe a little HP not much
but the deep sound is cool .. when you break it in its a lil louder too
Old Feb 26, 2009 | 07:27 PM
iamsuperbleeder's Avatar
break it in? wth do you have to break in?
Old Feb 26, 2009 | 08:50 PM
xzyragon's Avatar
u don't have to break anything in
however, i did notice that after my truck sitting on a tank of gas for 2 months was refilled, it ran a lot better. More power, pickup, gooseage...
i don't know if i had gas pump andrenaline or what...
Old Feb 27, 2009 | 11:56 AM
Tick's Avatar
If you don't want the cold air intake, can you take it off and put the air box back on or are you wrecking the air box so it cant be reused ?
Thanks for all the info .....
Old Feb 27, 2009 | 12:32 PM
yotakid825's Avatar
yep you can just put the stock intake/airbox back on if you don't want the aftermarket on.
You don't need to cut up the stock air box to remove it. Just unbolt it.
