88 4Runner power windows
Old Feb 26, 2009 | 04:08 PM
Gordo's Avatar
I am a newbe to this board. Former Jeep owner who has seen the light. I have owned this 4 runner for 3 weeks
I am having a issue with the power windows on the doors not the tailgate. After searching I can't find much on this issue. Windows worked for one day after I bought it.
There is no power getting to the switch. I checked the circuit breaker it is fine. I think I am going to run a hot lead to the window harness and use it to power the windows. Before I do this is there something else I should consider?
Old Feb 26, 2009 | 04:45 PM
phildelfino's Avatar
Some have taken the switches apart to clean them.
Mine work so I am no help in that regard.
Old Feb 26, 2009 | 05:06 PM
Gordo's Avatar
Thanks I did that. Guess I should of put that in my post
Old Feb 27, 2009 | 06:51 AM
sotb3's Avatar
i know this sounds silly but did you make sure that the window lock was in the correct config.?
Old Feb 27, 2009 | 08:22 AM
Gordo's Avatar
Yeah I double checked that. Thanks for your reply!
Old Feb 28, 2009 | 06:09 PM
Gordo's Avatar
Power Window Fixed
Ran power to the master door switch to make sure both motors were good. Windows went up down off switch. By the way the power feed is the blue on the switch side after connector in door. Traced back in harness following power wire. Once inside the cab found wire inside kick panel. Ran wire (fused) from battery spliced into power wire. Have power and both front windows work as they should. Now
I can open and close window with engine turned off.
By the way confirmed with Toyota that 1988 four runners do not have a relay only a circuit breaker.
Old Feb 28, 2009 | 06:11 PM
waskillywabbit's Avatar
So you didn't "fix" it with the OEM wiring but ran some new? Or am I missing something?
What was wrong?
Old Mar 1, 2009 | 09:47 AM
Gordo's Avatar
Used OEM wiring. All I did was tap into another power source. So the only non OEM is the wire from the battery to the original power wire. The switches are the same as well as all the wiring with the exception of the one wire. I tried first to run the original power wire to the source and could not trace it. So everything works like OEM with the exception of the one wire from the battery to power the switch. I only ran the battery wire into the cab then tapped in to the wiring harness to the wire that powers the switches. Hope that helps.
Jun 1, 2021 01:51 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
skoti89
Jul 8, 2015 12:05 AM
musashi86
California SoCal
Jul 7, 2015 03:31 AM
coryc85
Jul 6, 2015 04:07 AM
