question on idling
Old Feb 22, 2009 | 07:43 PM
xzyragon's Avatar
question on idling
So, i replaced the distributor and timed the engine by ear (i am gonna get it timed w/ a light eventually as soon as my friend has some time). Its tuned to operate smoothly at 20-30 mph (i dont have a tachometer). Would this affect the rough idling?
It doesn't affect starting, as i can still goose it fine off a light, and it has the same, if not more power than before i replaced everything. I just think that it might be affecting my mpg. Sometimes i hear a clucking from the engine for 15 seconds as well.
I don't know how low exactly it is, but idle drops as soon as the engine is warm.
Old Feb 22, 2009 | 08:45 PM
myyota's Avatar
Your timing can affect the idle if its not set right, also a really worn out timing chain will affect the idle, a vaccume leak can affect your idle and a bad TPS can affect your idle, so many thing affect the idle, so you just have to check things out one at a time.
Old Feb 22, 2009 | 08:53 PM
abecedarian's Avatar
after the engine warms up and everything is dialed in... (whoops... did I say everything?)...
you jumper the diagnostic plug, and THEN set the idle and timing.
Old Feb 22, 2009 | 09:55 PM
xzyragon's Avatar
jumper the diagnostic plug?
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
luckypig44
Jul 19, 2015 11:25 AM
kyletbert
Jul 17, 2015 11:39 AM
