Transmission whine
Old Apr 21, 2013 | 02:00 PM
weaselman's Avatar
It sounds horrible. In first and third. Are they on the same shaft?
I have the trans out and torn apart. Everything seems to be okay. Except the oil was a metallic gold color (I'm guessing from the syncros getting muffed up?)
Would you replace these gears? Or just do a full rebuild of bearings and syncros?
Trans is out of. 90 4wd pickup. With 22re.
Attached Thumbnails Transmission whine-image-4028675228.jpg   Transmission whine-image-2719232617.jpg
Old Apr 22, 2013 | 02:53 PM
weaselman's Avatar
Bump for some advice.
Old Jan 7, 2014 | 07:42 PM
weaselman's Avatar
anyone have input?
Old Jan 7, 2014 | 07:58 PM
millball's Avatar
Hard to judge from pictures. Every gear is in constant mesh with other gears.
The tranny is shifted by locking and unlocking the gears on the shafts.
Is there no indication that one or more of the bearings are loose or rough??
Old Jan 7, 2014 | 08:05 PM
weaselman's Avatar
that is correct. all bearings are smooth and tight.
Old Jan 7, 2014 | 08:15 PM
xylicon's Avatar
Since you have it apart might as well rebuild it. I have a whine in my W56-B in 3rd and 5th gear, I finally rebuilt it after the input shaft bearing went out. The whine was still there after new synchros and bearings. I guess that's just how it sounds. Its been almost 30K miles since the rebuild and the whine hasn't gotten any worse or better, I'm not worried about it at all.
These transmissions seem pretty bulletproof to me.
spiewaker
Dec 16, 2015 01:10 PM
irv
Oct 1, 2015 09:49 PM
ToyotaMD
Sep 22, 2015 06:28 AM
briholt
Sep 20, 2015 10:26 PM
kelly1450
Sep 2, 2015 12:29 PM
