Can thermostat cause running issues?
Old Aug 2, 2019 | 02:05 PM
frikinyankee's Avatar
86 22re 4runner automatic
Hey so I've been trying to chase down an issue, the car runs underpowered when at temperature. When I first start it, it runs fine but idles a bit rough. Then when it's at temperature (or after driving around a while) it starts to have weak power. Like it'll have a hard time getting up to speed from a stop, and then once at highway speeds it often feels like from 1/4 to 3/4 throttle makes no difference. Also the automatic transmission struggles to shift sometimes with this lack of power.
So one thing I noticed is that my temperature gauge seems a bit low. I remember it used to go up past 1/2, then the thermo would kick in and would go down to about 2/5 and stay there for the rest of the ride. Now it slowly crawls up to 2/5, never really passes that. Sometimes it takes really long to get there.
So I'm thinking maybe my thermo is stuck open. I'll change it when I get a chance.. but the question is.. could this cause running issues? I know the ECU takes signals from a few sensors to determine the mixture. I've tested most sensors and they seem to test fine. Could a cold engine temp cause a bad mixture?
Old Aug 5, 2019 | 01:40 PM
Bump.
No knowledge on running temperatures on fuel/air mixture?
Old Aug 5, 2019 | 04:59 PM
Paul22RE's Avatar
5 Year Member
Your MPG would suffer slightly if engine never reaches operating temp, but I would say you have another issue going on.
Old Aug 6, 2019 | 02:45 AM
arlindsay1992's Avatar
It will affect how it runs. It happened to me. I usually get around 17 or 18 MPG but on one tank I got around 12 or 13 MPG. This was strange so I started investigating. I checked the codes, there was a code for the engine coolant temperature sensor, so I replaced it. The light never did light up while driving, so I had no idea until I checked. If the computer thinks the engine is cold it will stay in open loop and keep things rich. I didn't notice any loss in performance though, so there's that.
retrobeast
Feb 28, 2019 05:14 AM
headgasket
Jul 2, 2012 10:30 PM
devldogs55
Mar 27, 2011 11:27 AM
Harold Of The Rocks
Jan 28, 2009 07:11 PM
Mojo_Risin
Apr 2, 2008 07:31 AM
