Random Spliced in Vacuum Line?
Old Jul 25, 2019 | 01:34 PM
Neemox's Avatar
Hey all, I am cleaning up this 22RE out of a 1985 prior to swapping it into my 1987. I found what looks like a random spliced in vacuum line on one of the power steering vacuum lines.
Anyone have a guess as to what it was for? Any reason to keep it? I'm planning on just replacing the entire vacuum line without the splice. The spliced in line terminates in a cut tube, about 3 ft long, so maybe it ran to something near the firewall? The 1985 motor had cruise control, and my 1987 does not, but I don't think the cruise control has anything to do with vacuum.
Old Jul 25, 2019 | 03:14 PM
old87yota's Avatar
That splice is not factory, so you can safely get rid of it.
My guess is that someone used that for a vacuum gauge, but I don't really know.
Old Jul 26, 2019 | 03:39 AM
ev13wt's Avatar
5 Year Member
You should have a schematic under your hood
Old Jul 26, 2019 | 09:02 AM
Neemox's Avatar
Sadly, that sticker is long since gone under my hood, and this is on the motor I'm swapping in, which comes from a different year. I'm pretty confident the splice was not there stock, but just wanted to see if it was an aftermarket piece I would want to keep or something.
Old Jul 26, 2019 | 09:27 AM
scope103's Avatar
Originally Posted by Neemox
... The 1985 motor had cruise control, and my 1987 does not, but I don't think the cruise control has anything to do with vacuum.
Cruise control has everything to do with vacuum; that's what drives the throttle actuator. (Some 4runners have an electric actuator, but I think it came out in '95.)
As others have pointed out, the Tee is clearly not factory (not even factory cruise), so it's anyone's guess what's going on there. I doubt there would be any good reason to keep it (another point of possible failure). And you could always add it back in later with a real vacuum Tee if you needed it.
Old Jul 26, 2019 | 09:37 AM
Neemox's Avatar
Makes sense to me, I'll pull it out and put a new line in there. (And then I'll start troubleshooting how the cruise control actually hooks up, haha.)
Thanks all!
Old Jul 26, 2019 | 09:49 AM
old87yota's Avatar
Do you have a factory cruise control system?
Old Jul 26, 2019 | 09:59 AM
Neemox's Avatar
I have the cruise control system that looks like it has an ECU connector and a place to attach a throttle cable? (maybe?) that is supposed to bolt up near the brake booster, and then I got the steering column and dash panel that have the cruise control switch and actuator on them. Haven't looked much more into it than that. I got the engine and the cruise control parts from the same guy, but I am not sure that they came out of the same truck, he parts a lot of trucks out apparently.
When I get home on Monday I can take some pictures of what I actually have, but it looks like the same piece as shown in the pic from https://www.yotatech.com/forums/f116...e-body-297332/
Old Jul 26, 2019 | 12:34 PM
old87yota's Avatar
That is a factory unit, so you should be good to go!
Unbrakeable
3.4 Swaps
7
Apr 23, 2015 06:27 PM
pcalert
Nov 3, 2012 09:52 AM
ashamsuddin
Aug 3, 2012 11:22 AM
Smeddy2
Oct 4, 2010 10:12 AM
