What is this noise? ‘87 22RTE
Old 07-14-2019, 04:09 PM
Charles4x4's Avatar
This noise just popped up a few days ago. I checked the belts and tension seems fine. I’m hopeful the PS Belt is just slipping? I think it only has 4K miles on it though.
The noise seems to be coming from the PS Belt / Distributor / PS Pimp area.
‘87 22RTE that was fully rebuilt by a guy who did the work for the PO 4K miles ago.
Any ideas?
Old 07-14-2019, 06:21 PM
Co_94_PU's Avatar
Metal on metal screech, probably the tensioner bearing, it has a pretty distinct ring to it compared to belts squeel/slippage.
If it was the pump it would be a bit more muted and a different frequency.
Old 07-15-2019, 12:45 AM
ev13wt's Avatar
Put some oil / grease into the above mentioned bearing and see if it goes away
Old 07-15-2019, 02:20 AM
Melrose 4r's Avatar
I think tensioner or A/C clutch bearing. Remove belts to see.
Old 07-29-2019, 04:10 AM
Melrose 4r's Avatar
Have you determined what it was?
Old 07-29-2019, 04:19 AM
Charles4x4's Avatar
Distributor went out! Now it has a brand new distributor and all is well.
The following users liked this post:
old87yota (07-29-2019)
Fastbug
12-03-2016 07:45 AM
JWillyG
12-08-2010 06:19 PM
83Chero
04-21-2009 09:54 AM
dkubz
01-19-2009 07:06 AM
BluYot
05-13-2008 04:05 PM
Quick Reply: What is this noise? ‘87 22RTE
