94 Pickup Rostra Issues
Old Aug 27, 2019 | 03:55 AM
TheEchoHotel's Avatar
I’ve had a Rostra cruise control in my 94 Pickup (22re/AT) for over 6 years. Over the past month, the speedometer started fluctuating +/- 5mph when the cruise started accelerating. It does it until i come to a stop.
Anyone had these issues before or know what may be causing it?
Thanks,
EH
Old Aug 27, 2019 | 06:16 AM
keycw's Avatar
5 Year Member
is the 94 still a cable speedo or is it electronic?
Old Aug 27, 2019 | 07:03 AM
scope103's Avatar
Posting to lots of forums and just using cut and paste with your message?
Welcome to YotaTech.
You probably have the electronic speedometer. When the sensor starts to fail, the speedometer will drop (to zero?) and then pop back up. As it progresses, the time "dropped" increases. (But I wouldn't describe it as fluctuating ...)
The sensor can be tested, but since it's an intermittent problem, you may have a tough time catching it while malfunctioning.
Old Aug 27, 2019 | 03:33 PM
Yes.. I like to see if I get any different responses from multiple sources.
It doesn't drop to zero... If I set the cruise at 70, it fluctuates from 60-75 and continues to do that until I come to a stop.
Old Aug 28, 2019 | 02:43 AM
keycw's Avatar
5 Year Member
well if you are sure its the cruise control just unplug it. then you can rule it out.. otherwise you obviously already have your answer, the speed sensor is bad, as scope said
Old Aug 28, 2019 | 10:56 AM
old87yota's Avatar
Does this problem ONLY happen with the Cruise Control?
I would take Keycw's advice and unplug the cruise control from your wiring harness and see how the speedometer works with the cruise control disconnected.
Mudd Duck 1
86
Aug 31, 2013 03:39 AM
BLASHTRADER
Aug 13, 2009 10:18 PM
scarymonster
Apr 19, 2008 10:15 PM
scarymonster
Apr 19, 2008 04:19 PM
