torsion bars
Old Aug 24, 2008 | 05:44 AM
nickmell's Avatar
torsion bars
is there anywhere i can get just one left side torsion bar for a 94 4x4 pickup? mine desided to snap yesterday and i can only find sets of them ... thanx
Old Aug 24, 2008 | 05:48 AM
dirtoyboy's Avatar
junkyard...go pull one out
Old Aug 24, 2008 | 05:59 AM
toyminator2000's Avatar
v6 are bigger than 4cyl make sure you match
Old Aug 24, 2008 | 06:06 AM
scuba's Avatar
Toyminator, when you say bigger do you mean longer?
or bigger circumfrence.
If you mean circumfrence, then my theory says that if you swap out a pair of the v6 for the 4banger t-bars, that they would be a bit stronger..
Would this be possible, and am i thinking in the right direction?
Old Aug 24, 2008 | 06:22 AM
dirtoyboy's Avatar
Arent the spline counts different?
Old Aug 24, 2008 | 06:24 AM
nickmell's Avatar
well i figure im probly beter off just geting new .... do these look any good? i dont really do much off roading.
Old Aug 24, 2008 | 06:31 AM
dirtoyboy's Avatar
get some 26 mm downey bars...then you can crank em up without worry
http://www.downeyoff-road.com/Suspen...s/1986-95.html
I ran these bars for many years and they worked great...less preload than a cranked stock t-bar
Old Aug 24, 2008 | 06:48 AM
unclejstoy's Avatar
Heres my 2 cents. Do both at the same time your alignment/ride quality will thank you. also order new bolts from the toy dealer most likely they will snap on you. and why you have it apart do the bushings.
Old Aug 24, 2008 | 06:51 AM
mt_goat's Avatar
Since Downey list one part # for all 86-95 IFS trucks... I'll bet the 4 cyl and V6 trucks both share the same bars.
I'm running the Downey bars too, but I have a winch bumper and winch and 33" tires.
Hey Dirtoyboy, I'd like to get that CV from you we had a chat about last week. PM me please.
Old Aug 24, 2008 | 07:05 AM
scuba's Avatar
shoot i thought your the low down yota parts man.
Old Aug 24, 2008 | 07:26 AM
nickmell's Avatar
i guess a link would help http://cgi.ebay.com/ebaymotors/Ironm...spagenameZWD1V
Old Aug 24, 2008 | 07:29 AM
nickmell's Avatar
i read that the 26mm one give a rough ride quallity is this true... i also have 31" tires on it if it matters
Old Aug 24, 2008 | 07:40 AM
mt_goat's Avatar
Yeah they tend to do that, even though Downey says they don't. Adjustment is more critical for sure. Where are you located?
Old Aug 24, 2008 | 07:45 AM
abecedarian's Avatar
The 25mm bars on my 2wd stiffened the front up about 50% and it rides quite a bit firmer (almost too stiff for the street) than the stock bars and the tires went up from 195/75r15's to 235/75r15's- approximately 26.5" to 28.75" so just over 2" taller. So I'd imagine a larger bar would be comparable on the heavier 4wd.
Old Aug 24, 2008 | 07:47 AM
dirtoyboy's Avatar
I didnt think they were all that stiff.....not near as stiff as a stock bar cranked to the same height....
Old Aug 24, 2008 | 08:05 AM
nickmell's Avatar
i live in md .... i had the stock ones cranked up for the lift scince i have 2 inch blocks in the back... would these be to stiff t do tha with?
Old Aug 24, 2008 | 08:23 AM
unclejstoy's Avatar
I have 26MM i got from performance products took a while 2 set them where i like them. I got the truck level and left them there, and yes it's a harder ride. But i have plans for a deer killer bumper.
Old Aug 24, 2008 | 08:30 AM
mt_goat's Avatar
I might just add that a harder ride does have some nice handling effects in the corners.
I have a set of used stock bars I'll sell.
Old Aug 24, 2008 | 09:33 AM
iamsuperbleeder's Avatar
here's my question about the 26mm bars...
how's the flex with them cranked; with and without the swaybar removed?
sorry to hijack the thread
Old Aug 24, 2008 | 10:02 AM
mt_goat's Avatar
This pic is with Downey 26mm bars, sway bar discoed.
Worrying about flex with a sway bar connected is a little like a 300 lb woman worried about the weight of her bicycle seat.
