4x4 issues
Old Aug 26, 2008 | 04:40 PM
TheUglyDuckling's Avatar
4x4 issues
Alright... it's an IFS '87 and my 4x4 is not working.
front hubs locked, in 4x4 only the rear wheels are going.
I don't think my cv's are broken, but i have one front hub that is VERY tight and i have to lock it in with a screwdriver or something... as in its too tight to turn by hand.
Would that be enough to cause my problem?
Old Aug 26, 2008 | 04:56 PM
INFINITY's Avatar
if one of the springs in the hub has broken or popped off it could be stuck in the unlock position. just take the outer hub off and look at it. just mark it with a marker then take the 10mm bolts out with the hub set to free.
follow the instructions http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Old Aug 26, 2008 | 05:01 PM
tc's Avatar
tc
Does the 4WD light come on?
Old Aug 27, 2008 | 02:53 PM
4wd light does come on and it will go into 2 low and all that. i'm kind of leaning towards the hub thing... my front brakes were done about 2 months ago also. i'll take a peek at the spring today.
thanks for the link btw
Old Aug 27, 2008 | 03:45 PM
Jay351's Avatar
I bet the hubs are not put together correctly. Remove the cover and take a peek. They are a little tought to understand the first time (mostly the spring and prawl setup) but once you have done it once, its darn easy.
Here is the best picture by pictures writeup of rebuilding aisins that I have found. With it, the newest of noobs can rebuild these things.
http://forum.ih8mud.com/79-95-toyota...b-rebuild.html
I bet if you jacked up the back of your truck, locked the hubs and put it in 4wd. You will be able to see the cv joint going to that "tough" hub spinning. It will be the easiest axle to spin so all the power in the front will be sent there.
Old Aug 27, 2008 | 11:51 PM
fixed! the hub was retarted... unbolted it and it sprung out all over the place. wasn't hard to understand at all...
brake cleaned it all and rubbed some thick grease on it. feels like new.
thanks fellas.
MO transplant
Apr 23, 2023 11:58 AM
mskalmus
May 28, 2017 07:51 AM
raptor510
Feb 17, 2017 07:11 AM
smiley52
Jul 11, 2015 05:16 AM
Coreyr384
Jul 10, 2015 11:13 AM
