First time off the pavement in the 4RNR
Old Aug 21, 2008 | 11:23 PM
chrisbnaz's Avatar
Earlier the gf and I went out for a few to take some pics for the yotatech calender.
Havent had the runner long, this was the first time I've had the chance to play around with it a little off road...When I put it in 4low to go up a pretty steep hill, it just spun the tires. I know I don't have the best off road tires, but it shouldnt of been that bad..So I backed up a little bit, stayed in 4low but this time in 2nd gear when I got to the base of the hill..went right up without flinching.
We were out around a soft sand dry river bottom, had to through it a little to get out there and a little to get out on the way back. Again in 4low, just spun the tires..4low in 2nd gear and it cruised over the sand no problem..
I'm still new to toyota trucks and I'm still learning, but whats the reduction in gear ratio in 4low on these things? Is it really that much where being in 1st gear in 4low will just spin the tires? The runner has bfgs, but theyre not all terrains or anything, just standard radials.
When I had my Jeep XJ, it had about the equivelant in tires, but in 4low it would basically idle up whatever I want it to and I damn sure never blew the tires off it lol.
Old Aug 21, 2008 | 11:54 PM
Matt16's Avatar
Stock crawl ratio is about 45:1
Old Aug 22, 2008 | 05:26 AM
Junkers88's Avatar
/hijack/ Matt do you know what the gear ratios are in the tranny (1st gear) and t-case (4low)? /hijack/
Old Aug 22, 2008 | 12:07 PM
chrisbnaz's Avatar
Ha. So I was laying in bed thing last night...Realized I forgot to lock the hubs. haha.
Old Aug 22, 2008 | 12:12 PM
bigt's Avatar
i did the same thing!!! got stuck on a flat slick surface..then when i locked the hubs i did this!!!
http://www.youtube.com/watch?v=KHDHs1CS0E4
then my afm went on me!!
Old Aug 22, 2008 | 03:45 PM
kramykram's Avatar
BLAAH BLAAAH BLAAAH BLAH BLAAH BLAAH BLAAH BLAH BLAAH BLAAAH BLAAAH BLAH BLAAH BLAAH BLAAH BLAH BLAAH BLAAAH BLAAAH BLAH BLAAH BLAAH BLAAH BLAH BLAAH BLAAAH BLAAAH BLAH BLAAH BLAAH BLAAH BLAH BLAAH BLAAAH BLAAAH BLAH BLAAH BLAAH BLAAH BLAH BLAAH BLAAAH BLAAAH BLAH BLAAH BLAAH BLAAH BLAH BLAAH BLAAAH BLAAAH BLAH BLAAH BLAAH BLAAH BLAH BLAAH BLAAAH BLAAAH BLAH BLAAH BLAAH BLAAH BLAH BLAAH BLAAAH BLAAAH BLAH BLAAH BLAAH BLAAH BLAH BLAAH BLAAAH BLAAAH BLAH BLAAH BLAAH BLAAH BLAH BLAAH BLAAAH BLAAAH BLAH BLAAH BLAAH BLAAH BLAH BLAAH BLAAAH BLAAAH BLAH BLAAH BLAAH BLAAH BLAH BLAAH BLAAAH BLAAAH BLAH BLAAH BLAAH BLAAH BLAH BLAAH BLAAAH BLAAAH BLAH BLAAH BLAAH BLAAH BLAH BLAAH BLAAAH BLAAAH BLAH BLAAH BLAAH BLAAH BLAH.
Old Aug 22, 2008 | 05:28 PM
scuba's Avatar
yesssss !!!
Old Aug 22, 2008 | 08:12 PM
tc's Avatar
tc
Depends on the tranny, but most 1st gear is 3.83. Turbos had a 4.31 first gear.
Gear drive tcase is 2.28:1
Chain drive tcase is 2.56:1
Old Aug 22, 2008 | 08:13 PM
tc's Avatar
tc
To the OP - sounds like you need to work on line selection. Sounds like you got wheels off the ground and didn't have enough speed in 1st to bridge the gap, then in second you did. That's OK sometimes, but generally, you want to take the obstacle as slow as possible to minimize damage.
Old Aug 22, 2008 | 09:16 PM
abecedarian's Avatar
like mentioned....
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
smiley52
Jul 11, 2015 05:16 AM
