knock sensor torque specs?
Old Aug 22, 2008 | 04:12 PM
Dusty19's Avatar
I have looked in a lot or repair manuals and online and i can not find the torque spec. for my 1992 4Runner 3VZE. Does anyone know the spec. off hand or where i may be able to find it?
Old Aug 22, 2008 | 04:42 PM
abecedarian's Avatar
the knock sensor doesn't need a lot of torque. it is basically a piezo-electric microphone that picks up vibrations from the engine block and sends signals to the ECU. as long as it is more than finger tight and has no thread sealing compound on it (other than maybe an anti-sieze lubricant) the torque should be fine- maybe 10 lb-ft max is enough.
Old Aug 22, 2008 | 04:43 PM
Dusty19's Avatar
ok thanx
Old Aug 22, 2008 | 05:31 PM
Green93's Avatar
No thread sealing compound? Is this a rule? I had the same problem with my rebuild, I couldn't find specs anywhere. I just ended up putting 2 drops of blue liquid loctite and tightening it to about 15lb ft. Is this going to cause a problem?
Jason
Old Aug 22, 2008 | 06:20 PM
by sealing compound I meant like teflon tape.
blue loctite is probably okay.
Old Aug 23, 2008 | 05:30 AM
Dusty19's Avatar
and does the injector rails have to have a torque to?
rustym
Aug 7, 2015 10:39 AM
Flossy
Aug 5, 2015 05:14 PM
colasurdo
Jul 18, 2015 07:06 AM
colasurdo
Jul 17, 2015 08:28 AM
