Rear R&P
Old Aug 23, 2008 | 10:56 AM
Bigblock's Avatar
Rear R&P
It's been a while so bear with me.I have the task of rebuilding my rear third and have a question or two.I have factory 4.87's and I know to use another carrier,I have a 4.10.What pinion shim should I start out with?The old one out of the 4.87?Where should I buy the gears and bearings?
Bigblock
Old Aug 23, 2008 | 05:37 PM
tc's Avatar
tc
Not sure I understand the question...
If you have factory 4.88's you need a whole new thirdmember, not just a carrier since the housing for the third has the pinion offset for the 4.88.
Old Aug 26, 2008 | 05:09 PM
Bigblock's Avatar
Yes the whole thing is what I have.Sorry for the confusion.I will be using the 4.10 3rd with the new 4.87 gears.I just hate to trial and error the shims when there is a shot at getting them right on the first try.I don't have the tools to do it perfect on the first try.
Bigblock
Old Aug 26, 2008 | 06:09 PM
DeathCougar's Avatar
Where did you get the 4.88 gears from? If they are after market, its ok. If they are factory, you cannot use them due to the offest design tc was describing.
Old Aug 27, 2008 | 05:48 PM
Bigblock's Avatar
I don't have them yet but when I buy where should I get them?I was thinking Randy's.They wont be from the dealer!
Old Aug 27, 2008 | 05:52 PM
dropzone's Avatar
Fossilized
for some write ups you might want to check out Zuk's website, http://gearinstalls.com/ he has a ton of info on there, you might find out some more info there...
Old Aug 27, 2008 | 06:26 PM
Bigblock's Avatar
Thanx I'll try that.
Bigblock
okamikai
Apr 30, 2018 10:19 PM
kirkrunner
Jul 27, 2015 07:59 PM
SMOD
Jul 27, 2015 01:45 PM
Athansinis
Jul 27, 2015 08:38 AM
icentropy
Jul 14, 2015 10:23 AM
