Rear R&P
Rear R&P
It's been a while so bear with me.I have the task of rebuilding my rear third and have a question or two.I have factory 4.87's and I know to use another carrier,I have a 4.10.What pinion shim should I start out with?The old one out of the 4.87?Where should I buy the gears and bearings?
Bigblock
Bigblock
Yes the whole thing is what I have.Sorry for the confusion.I will be using the 4.10 3rd with the new 4.87 gears.I just hate to trial and error the shims when there is a shot at getting them right on the first try.I don't have the tools to do it perfect on the first try.
Bigblock
Bigblock
Where did you get the 4.88 gears from? If they are after market, its ok. If they are factory, you cannot use them due to the offest design tc was describing.
for some write ups you might want to check out Zuk's website, http://gearinstalls.com/ he has a ton of info on there, you might find out some more info there...
kirkrunner
Jul 27, 2015 07:59 PM
Athansinis
Jul 27, 2015 08:38 AM
icentropy
Jul 14, 2015 10:23 AM
