4runner to pickup engine swap
Old Aug 18, 2008 | 08:12 PM
bubba osu1's Avatar
does anybody know if a 3.0l out of a 1990 4runner with a automatic transmission swap into a 1991 pickup with a 3.0l and a manual transmission without alot of hassel
Old Aug 18, 2008 | 08:17 PM
SpecialScottie's Avatar
Just taking the 3.0 out is a hassle.
I couldnt imagine trying to swap it
Good luck though
Old Aug 18, 2008 | 08:52 PM
Elvota's Avatar
You'd have to address the wiring as well as the ECM differences.
Auto ECM's look for different info than manual ECM's.
As far as fit... no problem. Should even be able to swap trannies, just make sure the 3.0 that will be mating to the 5spd has a place for the pilot bearing.
Old Aug 19, 2008 | 05:53 AM
zlathim's Avatar
It will work fine. There should be no reason to worry about wiring or ECM differences if you are just swapping the engine. You will need to install a pilot bearing for the manual trans, and you will likely have have 1 extra coolant temp sensor (blue in color)that you can just leave unhooked.
Old Aug 19, 2008 | 06:14 AM
mt_goat's Avatar
Yeah you'll want to keep the 91 engine harness in place and just swap the engine. Its more of a hassle that way because you have to remove the intake to get to the fuel injector plugs but its still better than rewiring stuff to the ECU.
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
Outsane
Jun 24, 2015 05:52 PM
TheManOutside
Jun 18, 2015 03:32 PM
infinityisfive
Jun 16, 2015 06:51 PM
