need exhaust manifold torq specs please
Old Aug 28, 2008 | 12:09 PM
ThomasTedder's Avatar
Does anyone know the torq specs and if there is a particular tightening order?
Old Aug 29, 2008 | 11:44 AM
Swansen's Avatar
oops, i meant to get to this yesterday, but its 33 ft lbs
Old Aug 29, 2008 | 05:14 PM
Matt16's Avatar
33ft-lbs. There is an order but your fine just tightening the bolts in a bit of a criss-cross pattern. Tighten them to 20ft-lbs, then to 33lbs, use anti-seize.
Old Aug 30, 2008 | 02:05 PM
Thanks guys.
Old Aug 30, 2008 | 02:46 PM
toyota-erik's Avatar
Just tighten it until it starts to strip and back it off 1/4 turn. Then weld them so they never come loose.
Old Aug 30, 2008 | 04:51 PM
Swansen's Avatar
Yes, while your at it, you might as well just weld the head to the block also, that way you'll take care of any possible head gasket leaks....
Old Sep 2, 2008 | 12:05 PM
I can't believe I never thought of that.
Jayboy74
10
Dec 21, 2021 08:27 AM
Corvoid
Sep 4, 2015 11:55 AM
shrek99352
Aug 31, 2015 04:16 AM
