2 things: Lift plans... and in need of pictures
Old Aug 16, 2008 | 09:04 PM
Squeebs's Avatar
Can someone give me some pics of a stock height pickup with 15x8 wheels 3.75 backspacing?
I'm getting these Procomp wheels and will be running 31x10.50 mudders.
As for the lift...
The Downey economy lift (Torsion bars, 2" rear springs)
And then the wabfab front IFS lift...
When I put the lift on, I plan on running 32x11.50 mudders....
This is the 90873947th time i've change my lift idea.... and i think this may be a really good system.
thoughts?
Old Aug 16, 2008 | 09:44 PM
t0mwat3r's Avatar
As for the lift...
thoughts?
IIRC you should be able to run the 32 x 11.5 without a lift
Old Aug 17, 2008 | 03:17 PM
hmmwv15's Avatar
Old truck at stock height running 235/75/R15's (29")
As for lift, I just cranked the torsions a bit, but you have to get the front end aligned if you do the same. I'd run some ball joint spacers and crank the torsions as well as your 2" lift springs, and it should give you a nice even 2" lift. As far as wider tires I can't really help you there.
Old Aug 17, 2008 | 03:46 PM
abecedarian's Avatar
I wouldn't do the downey torsion bars unless you're planning on adding a heavy front bumper- the ride will be too rough without some extra weight up there. If the stock bars are too soft for your liking, put shocks up front with higher rate jounce dampening, that way you won't lose some of your flex.
+1 on BJ spacers. And if the AAL's aren't enough to level the rear with the front, extended shackles from procomp or 4crawler. 4crawler can work with you to figure out what you need for shackle length.
31's should fit without a lift at all. 32's won't require much of a lift, since they're only ~1/2" larger radius.
Old Aug 17, 2008 | 03:53 PM
yoder519's Avatar
i jump on threads like this. 31x10.50s, procomp series 97 black steelies, 3.75 BS
Old Aug 17, 2008 | 03:54 PM
Originally Posted by yoder519
i jump on threads like this. >snip<
that explains the headache I just got.
...nice looking truck though.
for reference, got pics of the clearance between the tires and fenders/valance when at full lock?
Old Aug 17, 2008 | 03:57 PM
yoder519's Avatar
i bought a lift similar to that one- 3inch tuff ory AALs from topoguncustomz.com, 1.5inch bj spacers from 4crawler.com, and im gonna crank my tbars a bit. cost me like $160 all together, and i got new procomp shocks so about $280 for the whole kit n k bootle
Old Aug 17, 2008 | 04:00 PM
yoder519's Avatar
no sorry i got some on my camera i just took yesterday but i aint got the cord here at my house so i cant upload em. but they dont scrub tho if thats what your wondering. its pretty close tho
Old Aug 17, 2008 | 04:11 PM
toyNG's Avatar
I've also heard that the Downey torsion bars are super stiff.
I vote for going with the BJ spacers. Get them from 4crawler. The man know his stuff!
Old Aug 17, 2008 | 04:14 PM
that's what I was wondering- how close they are to rubbing.
yoder519's Avatar
ya dang right! i live in va and he sent em from cali and got here in about 3 days. i was impressed
Old Aug 19, 2008 | 01:38 PM
trbizwiz's Avatar
do the spacers require different shocks? longer?
Old Aug 19, 2008 | 01:54 PM
iamsuperbleeder's Avatar
that tread pattern looks familiar...
irronically, also 31x10.5s on 15x8s, but I wish I had black steelies, lol
Flying91
45
Apr 11, 2024 04:39 PM
nvdesertrunner
May 11, 2020 08:18 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
nickbeauregard
12
Aug 7, 2015 06:04 AM
4Runnin2000
Jul 29, 2015 06:09 PM
