black smoke?
Old Aug 24, 2008 | 11:55 AM
galloway's Avatar
black smoke?
so i have black smoke coming out of my tail pipe. is this ok cause i just rebuilt my mortor and i want to make sure everything is going good still
Old Aug 24, 2008 | 11:59 AM
DeathCougar's Avatar
Black smoke is never a good thing....that means its dumping fuel
Old Aug 24, 2008 | 12:28 PM
galloway's Avatar
what do i do like how do i fix this
Old Aug 24, 2008 | 12:31 PM
galloway's Avatar
could it be cause my rings are not set yet
Old Aug 24, 2008 | 03:52 PM
abecedarian's Avatar
depending on the conditions around the smoking, it could also be ignition timing too advanced.
Old Aug 24, 2008 | 04:15 PM
galloway's Avatar
ya i think it could be that. and i have mass air flow sensor that came off a diff truck cause mine went to hell when i hit went under water. do you think it can be that? and i also think it might of came off a 4 cylender not a v6 but i dont think it would run at all if it was that
Old Aug 24, 2008 | 04:42 PM
it would run, it will run wrong. I owuld be willing to bet thats part of your problem.
Old Aug 24, 2008 | 04:48 PM
dj-86yota's Avatar
ya i've had similar problems with my truck. i had the carb rebuilt. then replaced the fuel pump and all fuel lines and my carb was still flooding. it got to the point to where i couldn't even keeping running. it's still not fixed but with a few adjustments to the idle speed and idle mixture screws i was able to drive it for over two hours and it still runs. maybe having a dealership adjust yours will fix it. idk know for sure tho.
Old Aug 24, 2008 | 10:19 PM
galloway's Avatar
what about my distributor cap, will the timing cause this to.
puddlepirate
Jul 30, 2016 06:29 PM
dzldust
7
Oct 6, 2015 05:39 AM
dbollier123
Sep 29, 2015 05:23 PM
whiteyota93
Sep 29, 2015 02:31 PM
charlie_fong
Sep 27, 2015 10:06 PM
