Symptoms of faulty TPS?
Old Aug 27, 2008 | 02:24 PM
scrid's Avatar
Hey all, just wondering if anyone can tell me what some of the minor symptoms of a faulty TPS are.
Thanks
Old Aug 27, 2008 | 03:42 PM
Jay351's Avatar
Symptoms include:
- Wandering idle ( 800 at one stop light, 1000 at the next)
- Bad mpg (lol?)
- Poor throttle response
- Lack of drop in idle when TE1 and E1 connectors are jumped
Unplug the TPS and if it runs better, you got some work to do.
Old Aug 27, 2008 | 03:52 PM
BoostinChick's Avatar
My issue is (and I have a bad TPS I tested it) is that the truck idles fine on a cold start but as soon as it warms up and I go into driver the truck starts to shake/run like crap.
Old Aug 27, 2008 | 04:09 PM
iamsuperbleeder's Avatar
I had all the symptoms listed about when my TPS took a crap...
Like Jay said, I unplugged mine and left it unplugged for 3 days till I got a new one cause it ran so much better.
So try that first and see what happens.
Good luck
Old Aug 27, 2008 | 04:25 PM
Good luck
Ya I don't think my TPS is as bad as that yet...when I unplug my TPS the car runs worse and I don't accelerate well at all either.
Old Aug 27, 2008 | 04:36 PM
bigt's Avatar
might not only be a tps issue.. on my trail rig i unplug the tps it runs great,,plug it in it runs like ass.. so i dont plug it in!
but this is a 22re
Old Aug 27, 2008 | 04:51 PM
hmmwv15's Avatar
haha.
Glad someone posted this. I think mine is crapola also. Tried to adjust it via 4crawlers site but my volt meter won't give a steady reading so I think it's gone.
Mine is hard to start, will turn the key upwards of 5 times and then when it does decide to run it will shudder for about 10-15 seconds then jump up to 1500 RPM. Once it warms up it will settle at 1000, and when it has been running I sit at stop lights and it drops to 7 or 800. Now that I know you can disconnect it, I'll try that tomorrow
Old Aug 27, 2008 | 05:05 PM
Lysmachia's Avatar
I can't belive one of you smart asses forgot this? "If you don't turn in your TPS then you get in trouble with lumberg"
Sorry /BS
Old Aug 27, 2008 | 05:07 PM
Originally Posted by hmmwv15
haha.
Normal idle should be around 800RPMS +/- 50 RPMS according to the FSM. Try the jumping of the connector trick while the truck is warmed up/running and see if the idle drops. Like I said once I unplugged my TPS the car ran like complete ass especially going uphill.
I also found it a LOT easier (3VZE) to take off the throttle body and use my ohmeter to measure what needed to be measured. I was able to re-use my throttle body gasket as well.
Old Aug 27, 2008 | 05:46 PM
The Stig's Avatar
is it a bad thing to run the car without the TPS plugged in?
Old Aug 27, 2008 | 06:01 PM
thook's Avatar
Sorry /BS
Mmmyeah....about those TPS reports....
BoostinChick...
This is debatable, but I believe you may be seeing the results you are by unplugging the TPS is because it's on the same circuit as the auto tranny. I'm forgetting at the moment exactly how this is, but it has some management over the tranny and consequent engine load. Sorry for the vaguery. I suppose I should get more details, but I'm feeling too lazy at the moment.
Old Aug 27, 2008 | 06:03 PM
thook's Avatar
If you have an auto tranny, see above post. Plus, IIRC, it affects......or can affect.....tranny shifting. That's about the extent of it other than fuel management.
Old Aug 27, 2008 | 06:09 PM
Lysmachia's Avatar
Lumberg stands coreected... for the first time in his life...
Ummmm YEAAAAH........
Old Aug 27, 2008 | 06:16 PM
thook's Avatar
Gawd....that movie kept me in stitches. "oooo....oooo".
Old Aug 27, 2008 | 06:32 PM
slacker's Avatar
My TPS worked just fine .. along with other units I tested .. my problem turned out to be the throttle body . throttle body shaft bushings to be exact ..
seems with th 260K I have on my unit , like a carb , the shaft bushing have warn , and now creating a vac issue .
Old Aug 27, 2008 | 06:38 PM
thook's Avatar
Wow....that's a new on me. Never heard of that happening. Something to keep in mind, I guess.
So, how'd you figure out it was the shaft bushings? What clues were there?
Old Aug 27, 2008 | 06:45 PM
Jay351's Avatar
That makes sence Corey. I might have to check mine, seemed ok but better safe then sorry!
Old Aug 27, 2008 | 06:54 PM
sorry to get off topic, but what in the name of all that is holy is up with your new avatar thook?
please tell me that's not really you...
Old Aug 27, 2008 | 08:59 PM
thook's Avatar
No, it's not me....although, rather similar in features. I'm much thinner, though. And, were that me, I wouldn't be wearing underwear.
(Too much info? )
About the avatar and where it came from........that's courtesy of a4runnerfreak....aka Tony the Mobster. I thought it was funny and too much like my silly side. So, there it is. Viewable for all. I've been pondering a change, though.
Old Aug 27, 2008 | 09:04 PM
(Too much info? )
had to come out of the "oil cap removed" thread, lol
