Panels
Old Aug 16, 2008 | 09:57 AM
forbiddenera's Avatar
Panels
Okay, so my 4runner is rusted to , and I want to make it look nice.
Is there somewhere I can buy prefabbed fiberglass panels or something? What options do I have?
I've never done any bodywork before but I'm down for whatever it takes.
This picture actually makes it look a lot better than it is:
This is what it looked like before some bodyfiller/undercoating?
Old Aug 16, 2008 | 10:16 AM
874runnersr5's Avatar
you live in calgary correct? if so we should make a run or a meet one day
anyways, this is a good site
http://www.toyotafiberglass.com/
Old Aug 16, 2008 | 10:18 AM
Jay351's Avatar
x2 on toyotafiberglass.com The owner is a member of the forums. Great guy.
Old Aug 16, 2008 | 10:19 AM
yeah honestly, im kinda thinking instead of fixing my rear 1/4 i should just buy the fiberglass
Old Aug 16, 2008 | 10:27 AM
Jay351's Avatar
Fiberglass never rusts... And since your in alberta......
Old Aug 16, 2008 | 10:28 AM
good guess, what gave it away?
i'm going to guess you watched me buy the truck on beyond?
and i'll definitely check it out
thanks
it'll be a while before i take this thing out.. basically need a new suspension first.
Old Aug 16, 2008 | 10:32 AM
well i did see your beyond post and 4wheeler.ca post to so it was only a matter of time you found yotatech
yeah, im talking nothing to intense just some mild wheeling.
Originally Posted by forbiddenera
good guess
thanks
Old Aug 16, 2008 | 10:33 AM
haha jay, your totally right.
Old Aug 16, 2008 | 10:35 AM
Jay351's Avatar
My truck spent some time in alberta *ugh*. Its not nice on toyotas..
Old Aug 16, 2008 | 10:45 AM
yeah, but mines in pretty good shape for being here for a while lol
Old Aug 16, 2008 | 03:23 PM
RobD's Avatar
I've bought some of Corey's stuff from Toyotafiberglass and he does good work. Be prepared to do some hands on, though, because aftermarket replacement panels usually aren't exact fit replacement parts. He makes his a little oversized, for example, so you can tweak them to your needs. Be prepared to buy a Dremel if you don't already have one and panel bonding adhesive. Most of your good autoparts stores will have it. I know of a place in Airdrie that sells the adhesive and the gun to squeeze it with. Set aside a few hours and have at it.
Old Aug 16, 2008 | 09:38 PM
Sounds like fun, I wouldn't mind doing the panels myself but I don't really have a way to mold them, maybe I have enough panel left to use that as a template.
Old Aug 16, 2008 | 10:52 PM
RobD's Avatar
Just buy Corey's. Pick up a spot weld cutter, a Dremel, and the panel bonding adhesive (basically like epoxy). You cut the old welds that hold your existing panels, clean up the junk hiding underneath, glue the new panels in place with the panel bonding adhesive, clamp, let set for 24 hours, then trim the excess.
http://www.toyotafiberglass.com/4runner.htm
1uzRunner
63
Nov 10, 2018 03:58 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
JPV
Sep 28, 2015 03:15 PM
toyotasaurus
Sep 24, 2015 03:30 PM
Buckaroo_Banzai
Sep 24, 2015 07:26 AM
