Oil in intake
Old Aug 25, 2008 | 05:45 PM
bikerbob's Avatar
Oil in intake
I pulled the intake on my 22re to clean it out. In the lower intake I found carbon build up,normal, but number 3 and 4 cylinders had some wet oil. Is it normal for there to be wet oil in only these two cylinders?
Old Aug 25, 2008 | 06:27 PM
just a 22re's Avatar
thats not normal man
Old Aug 25, 2008 | 06:35 PM
thook's Avatar
How many miles on the motor? Could be the oil rings are worn...and probably is.
Old Aug 25, 2008 | 06:38 PM
yeah but then theres a valve problem to then making it go into the intake unless your pvc is shot?
Old Aug 25, 2008 | 06:53 PM
MMA_Alex's Avatar
the pcv will allow some oil through and it'll gunk up the intake
Old Aug 25, 2008 | 06:56 PM
thook's Avatar
True this!
Hey Alex...long time!
Old Aug 25, 2008 | 08:58 PM
bikerbob's Avatar
The motor was rebuilt 55000 miles ago.
Old Aug 25, 2008 | 09:31 PM
MMA_Alex's Avatar
yeah, im back hanging around for awhile.
I wouldnt worry about a little oil in the intake. clean it out best you can
Old Aug 25, 2008 | 09:55 PM
thook's Avatar
Oh, in that case, shouldn't be anything to worry about. Just make sure the PCV valve is working correctly....as in, not sticking or anything.
On the other hand, did you do a follow up valve adjustment after the rebuild?
Old Aug 25, 2008 | 09:56 PM
thook's Avatar
Cool beans....
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
RatOmeter
Oct 22, 2015 03:17 PM
yourrealdad
Jul 29, 2015 11:08 AM
calderp
Jul 27, 2015 09:58 AM
87blyota
Jul 10, 2015 04:31 AM
