Hydraulic tensioner timing belt
Old Aug 22, 2008 | 07:54 PM
bigdaddy87547's Avatar
i know if you are doing a timing belt job, you should do all of the items, but is it necessary to replace the hydraulic tensioner? i purchased a timing kit from ebay whick included upper idler, tensioner pulley, water pump, and gasket. all from GMB (this supplier supplies most of the big parts stores waterpumps) for $106 + $22 shipping. all made in japan. anyway, after looking through the many threads about timing, i dont really get an answer.....
Old Aug 22, 2008 | 07:57 PM
DeathCougar's Avatar
Yes, you should replace it. The chain will wear grooves in the tensioner after time, so it needs to be replaced. Besides, why not do it while you are there anyways?
Old Aug 22, 2008 | 08:03 PM
i have timing belt. damn, i thought i had all of the components for the job.
Old Aug 22, 2008 | 08:06 PM
OH you have a 95 V6.
Well, in that case, its really up to you. The tensioner is pretty easy to replace, but they tend to be a little spendy. Myself, i would buy it just for the peace of mind. But really, i don't think those things fail very often, if ever.
Old Aug 22, 2008 | 08:15 PM
here is the exact reason i didn't buy one. i think i was looking at the wrong illustration from toyota.
this is a nice source to have as well.
http://www.trademotion.com/partlocat...26&catalogid=1
Old Aug 22, 2008 | 08:28 PM
toyotapartscheap.com
Old Aug 23, 2008 | 06:59 AM
GSGALLANT's Avatar
You don't need to replace it unless it's bad or it is leaking. Check that the piston protrudes out by the correct amount as per the FSM, and check that it can't be pressed in at all by hand.
Old Aug 23, 2008 | 09:43 PM
I appreciate it, i will be digging into it hopefully sometime this week. I look forward to getting rid of the annoying rattling that comes from the upper idler...
P.S. Is there any reason the upper idler pulley was designed the way it is? I have never seen coolant flow through one before on any vehicle.
Eggslinger
Jun 8, 2019 03:32 PM
thefishguy77
Jul 30, 2015 10:59 AM
nick b
Jul 11, 2015 04:38 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
