Where does this wire go??
Old Aug 17, 2008 | 08:17 AM
Stock91's Avatar
Red face Where does this wire go??
Well, I wrote "Re-attatch to throttle on the tape" and didnt tape the end where it goes. Thought Id remember. Memory does not serve, but Im sure its obvoius, just not to me anymore!! The thing comes out of the wiring harness that goes through the middle of the injectors, well, intake side.
22re motor
Hope these pics worked, if not Ill paste a reply link
Old Aug 17, 2008 | 08:25 AM
Elton's Avatar
that would be a ground wire looks like it attaches to that bolt hole on the 2nd pic
Old Aug 17, 2008 | 08:32 AM
EWAYota's Avatar
If my memory serves me correctly, I mounted that on one of the bolts that connect the intake chamber to the block. Its a ground so anywhere nearby really. I do know though that the hole Elton mentioned is left empty on mine too, before and after rebuild.
(checking my photobucket pics....)
Don't mind the black arrow. You can see the wire though in this pic.
Old Aug 17, 2008 | 09:18 AM
muddpigg's Avatar
X2 on the ground, mine is attached to the intake tube mating.
Old Aug 17, 2008 | 09:34 AM
Stock91's Avatar
Theres two wires there. First, I just attatched it to the trotttle cable bracket, thing started. The check engine light was on and I thought this might have something to do with it. Might check the codes next.
Thanks for all the info. Now I got 3 places to put it! LOL
Old Aug 17, 2008 | 10:12 AM
Stock91's Avatar
The check engine code just blinks I cant even read the thing. its fast.
Old Aug 17, 2008 | 10:28 AM
abecedarian's Avatar
if it's just continuous blinking, there's no code stored.
so maybe there's a problem around the alternator.
Old Aug 17, 2008 | 10:35 AM
Stock91's Avatar
OK. What would I look for? Dirty wire? Check the output? The interior gauge is registering around 18 volts I think.
I know I need to:
Adjust Timing
Replace battery
80Truck
Oct 12, 2025 07:25 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
ToyoToler
Aug 8, 2015 08:43 AM
Daneums
Jul 28, 2015 11:57 AM
TDonkey
Jul 26, 2015 10:14 AM
