Steering Gearbox
Old Aug 18, 2008 | 06:00 PM
T-1000's Avatar
Steering Gearbox
My power steering gearbox leaks like crazy from the input shaft.
I have a new seal on order from Toyota, will that fix the problem? Or should I just pony up the ~$200 and get a reman?
Old Aug 19, 2008 | 04:06 AM
WFO's Avatar
WFO
I went to the dealership to get this part and they told me I had to buy the back portion of the gear box. Something outrageous like $700. I put a bottle of trans stop leak and that fixed it for a couple months. Now it leaks so Im gonna buy a re-man.
Old Aug 19, 2008 | 08:20 AM
Elvota's Avatar
Here ya go:
https://www.yotatech.com/forums/f107...-boxes-151981/
Old Aug 19, 2008 | 08:23 AM
dirtoyboy's Avatar
What kinda fluid are you using? ATF or steering fluid?
Steering fluid WILL make your box leak...I've seen a box with new seals leak within hours using steering fluid....
Old Aug 19, 2008 | 03:45 PM
T-1000's Avatar
It came with a bottle of PS in it, so I used that for a while, I think it greatly exacerbated the leak.
Old Aug 19, 2008 | 03:46 PM
T-1000's Avatar
Originally Posted by Elvota
Thanks for the link.
Old Aug 19, 2008 | 03:57 PM
abecedarian's Avatar
T-1000
you may be okay flushing everything out then changing the seal you were going to change, then just using ATF.
See how that goes before you ante up for a new box.
Old Aug 19, 2008 | 07:21 PM
T-1000's Avatar
Originally Posted by abecedarian
T-1000
I'll let you know if it works, the seal should come in tomorrow.
DEXRON II this time around.
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
scott90
Oct 4, 2015 09:21 AM
ktm192k
Oct 1, 2015 08:47 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
