4x4 dash light quit working
Old Aug 18, 2008 | 12:34 PM
Stiffnferal's Avatar
94 p/u 3.0 SR5V6 5-speed
The warning light panel at the bottom of the main cluster seems to be working for at least some of the lights (E-brake for sure) but my 4x4 light does not seem to be working all of the sudden. My question is, are there any other places for me to look before I pull the dash? Or should I just go for it? Fuses all are fine...
Old Aug 18, 2008 | 12:35 PM
ozziesironmanoffroad's Avatar
how bout the indicator plug on the xfer case?
Old Aug 18, 2008 | 12:38 PM
904_runner's Avatar
Does it have A.D.D?
I believe if the light when out then that means the shift fork in the front diff tube quit working. Search Add or something like that. this has been covered before
Old Aug 18, 2008 | 01:09 PM
rdlsz24's Avatar
I also would check the wire coming from the transfer case first. Easy to just do a visual.
Rob
Old Aug 18, 2008 | 01:31 PM
Booosted Supra's Avatar
i had a similar problem with my 94 and it was loss of vaccum to the front diff, check your vaccum lines, they start on the passenger side fender well to the front diff, and also check the sensor on the front diff
Old Aug 18, 2008 | 02:16 PM
Thanks for the tips ... will follow up on them all.
Old Aug 18, 2008 | 02:17 PM
oh, but didnt mention that 4x4 still engages...just no light
Old Aug 18, 2008 | 02:19 PM
904_runner's Avatar
Have you verrified that the front wheels still lock together?
Id jack the front end up, put the transfercase in 4wd while the truck is on. And get out, and spin one front tire, if the other side spins then the front is indeed engaged.
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
It's prolly just the bulb. It's not that diffacult to pull the dash. Takes all of maybe 5-10 min.
Old Aug 18, 2008 | 06:04 PM
Jay351's Avatar
If the front end is getting power, its the bulb. The dash can be a little hard to take out the first time, but it seriously takes me 2 mins to get out now.
Bulb would be a #74. You could take this oppertunaty to change your dash lights to give a different colour too
Old Aug 18, 2008 | 07:49 PM
Matt16's Avatar
Isn't that light on the dash to tell you ADD has engaged as well? There is a sensor on the ADD diff that may be broken.
Valvoman
Jun 28, 2015 02:45 PM
gog1968
Jun 22, 2015 05:55 AM
Taz22R
Jun 21, 2015 04:44 PM
ShaunKris
Jun 17, 2015 04:33 PM
