wont start in the cold 3VZE 89'
Old Dec 26, 2008 | 12:55 AM
matt loves the snow's Avatar
Red face wont start in the cold 3VZE 89'
hay first timer here.....I drive a 89' 3.0 3VZE toy pickup 4x4 auto, and it will not start in the cold weather, it has spark, it turns over, and the fuel pump it pumping I've tried carb cleaner and either down the intake tube but no results were noticed. it sounds like it wants to fire ....but it just doesn't when it is warm or hot out it fires right up like a champ, problem....I live in the snow half the year! help me please I know my way around a car and tools so please dont hold back! thanx much
Old Dec 26, 2008 | 01:06 AM
85TurboRunner's Avatar
If your getting fuel and spark then air is the next problem. Anything froze up in the filter area?
Old Dec 26, 2008 | 09:40 AM
thook's Avatar
You either have a problem with the cold start injector or the cold start timing switch.
When the motor is cold, pull the cold start injector out of the upper intake manifold/plenum, have someone crank the motor. You should see fuel squirt in a rather strong stream. If not, start looking at the timing switch first. They are common to go out.
The timing switch is located on the back of the motor/manifold near the firewall. You'll see large coolant bypass hose going to the middle of it. The timing switch is to the left of it as your facing the firewall. It has a large black connector. Take a long wire and connect one end to the battery ground. Take the remaining end and probe it into the ground side of the connector. Not sure which side that is offhand (can never remember that detail, for some reason), but there's only two terminals giving you two trys, eh. Then, try and crank the motor. If it doesn't start, try the other terminal. If it still doesn's start, time to look at the injector.
Try the switch. If nothing there, then I'll get some instruction on the injector for you.
Old Dec 26, 2008 | 05:13 PM
buckz6319's Avatar
thook....sorry for sticking my nose in on this thread ....continue on
Old Dec 26, 2008 | 09:19 PM
thook's Avatar
Hehehehe......ya found me.
Yeah, I'll find your thread and post'em there.
Old Dec 26, 2008 | 09:37 PM
thook's Avatar
Well, I know you had a thread or two I was replying in, but in searching realized you were referring to my statement in this thread. Gerf!....
Here's how to test it...
http://personal.utulsa.edu/~nathan-b...29coldstar.pdf
What are you trying to troubleshoot? What's the problem you're having?
thanx i will try these tips tomarrow,as soon as first light comes around but now its like -2 and windy! O ya and dark.....on the good side, I had to call out of work and was forced to snowboard fresh pow all day long haha couldnt have broke down at a better time 4' fresh snow! yah marry x-mass
Old Dec 26, 2008 | 09:38 PM
thook's Avatar
PM me or start another thread so as not to hijack here.
bigjstang
Jun 2, 2025 03:56 PM
BushPig
Oct 29, 2022 06:26 AM
smiley52
Jul 11, 2015 05:16 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
